help with greddy turbo
im over here at school and havnt had a chance to find the manual online (bought the kit used) i already installed everything but i know theres a nipple off the wastegate on the turbo, can u install it to any vac source or does the nipple need to be hooked up to something specific like the IM
any other vac sources i need to hook up that are on the turbo? or it just the one off the wastegate? TIA... btw the its the td-05 18g turbo for 99 prelude
if you're running it w/ the internal WG, just hook it up from the turbo to the WG. It's pretty simple.
Or you can try blocking the nipple off from the turbo and hook up a vac source to your WG. I'm not too sure if that works well w/ internal WG's, but I have my external WG hooked up to my IM and the nipple on the turbo blocked off.
