Need help with swap problems
Old Aug 25, 2005 | 01:53 PM
TurtleEF3's Avatar
Default Need help with swap problems UPDATE!!!
Ok my car now runs and idles fine but when I give it gas to drive it sputters and jerks the whole car like no other. It is undrivable and I need to get it running now! Anybody have any ideas?
Modified by EFcivicHB at 5:34 PM 8/30/2005
Old Aug 25, 2005 | 05:05 PM
TurtleEF3's Avatar
Default Re: Need help with swap problems (EFcivicHB)
bump
Old Aug 25, 2005 | 05:26 PM
crxdriver89's Avatar
if u have fuel and spark, but no start, check to make sure your firing order is correct. i had the same problem with my sohc because the parts store told me the wrong firing order. switched 2 plugs on the dizzy, and it ran like a dream. just try switching em, it might work.
Old Aug 25, 2005 | 05:40 PM
TurtleEF3's Avatar
Default Re: Need help with swap problems (crxdriver89)
Yeah the firing order is right and I already tried switching the 2 dizzy wire but still no luck.
Old Aug 25, 2005 | 05:45 PM
Suck my DX's Avatar
i dont understand how u can be throwing a solid cel and a code 10...its one or the other..code 10 is for ur iat sensor...solid code usually means bad ecu...have u tried switching ecus with a known working one?
Old Aug 25, 2005 | 05:49 PM
TurtleEF3's Avatar
Yeah while I crank it I get a solid CEL and code 10. I'm going to try a new ecu soon. Any other ideas?
Old Aug 25, 2005 | 06:01 PM
Suck my DX's Avatar
Default Re: (EFcivicHB)
oh now i understand what u mean...check the wiring for ur iat sensor...possible the sensor is no good as well...i dont think the ecu is ur problem
Old Aug 30, 2005 | 04:36 PM
TurtleEF3's Avatar
bump
Dibble
12
Mar 3, 2005 02:23 PM
SunkistRex
Apr 12, 2004 10:27 AM
Sohc Driver
Sep 21, 2003 06:25 PM
Blaze45
Jul 2, 2003 07:58 PM
Babybluegsr92
Jan 24, 2002 05:31 AM
