Air/Fuel Ratio gauges work on b16's ????
Old Aug 25, 2005 | 11:33 AM
ApolloSpeed's Avatar
Default Air/Fuel Ratio gauges work on b16's ????
I got a deal on a Glowshift A/F ratio guage from a friend........it should work by just hooking up to my O2 sensor right ??
On a 94 B16a3 DelSol
Old Aug 25, 2005 | 11:35 AM
komat's Avatar
Default Re: Air/Fuel Ratio gauges work on b16's ???? (ApolloSpeed)
yes it will work but it be pointless without a wideband
Old Aug 25, 2005 | 11:41 AM
IHateJDM's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ApolloSpeed &raquo;</TD></TR><TR><TD CLASS="quote">I got a deal on a Glowshift A/F ratio guage from a friend........it should work by just hooking up to my O2 sensor right ??
On a 94 B16a3 DelSol</TD></TR></TABLE>
if by work you mean light up. you need a wideband o2 if you want to actually use it.
b204dr's Avatar
Default Re: Air/Fuel Ratio gauges work on b16's ???? (IHateJDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IHateJDM &raquo;</TD></TR><TR><TD CLASS="quote">
if by work you mean light up. you need a wideband o2 if you want to actually use it.</TD></TR></TABLE>
you mean you dont like the light show that almost seems like it goes to the music
Old Aug 25, 2005 | 11:44 AM
IHateJDM's Avatar
Default Re: Air/Fuel Ratio gauges work on b16's ???? (b204dr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b204dr &raquo;</TD></TR><TR><TD CLASS="quote">
you mean you dont like the light show that almost seems like it goes to the music </TD></TR></TABLE>
the light show is great, but I have this friend that's epileptic...
Old Aug 25, 2005 | 04:21 PM
so basically its pointless ?
Old Aug 25, 2005 | 04:56 PM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ApolloSpeed &raquo;</TD></TR><TR><TD CLASS="quote">so basically its pointless ?</TD></TR></TABLE>
Well, some people enjoy the look of the gauges, but when wired to the factory O2 sensor, they certainly aren't useful as any sort of tuning aid.
Old Aug 25, 2005 | 05:15 PM
Default Re: Air/Fuel Ratio gauges work on b16's ???? (Padawan)
WHY is it that the factory narrow band won't work ?
my Glowshift instructions say it will work with "all" narrow band sensors
.....will it not even give you a "ballpark" of how your mixture is ?
Old Aug 25, 2005 | 06:35 PM
Turbogixxer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ApolloSpeed &raquo;</TD></TR><TR><TD CLASS="quote">.....will it not even give you a "ballpark" of how your mixture is ?</TD></TR></TABLE>
Yes, it will tell you if you are around 14.7 a/f or not. Thats it.
Old Aug 25, 2005 | 10:56 PM
Default Re: Air/Fuel Ratio gauges work on b16's ???? (Turbogixxer)
OK....NOW I'M CONFUSED OR STUPID......
cause why would I need it to tell me anything else?? If it will tell the the A/F ratio...... that's all I wanted to know anyways.
What else were you guys talking about getting out of this ?
Modified by ApolloSpeed at 12:14 AM 8/26/2005
Old Aug 25, 2005 | 11:35 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
But it really won't tell you the A/F ratio. Trust me, its pretty useless.
Wideband =
iaredavid's Avatar
h-t will do that to you
look, an a/f gauge will "work" with a factory narrowband. it will either register as lean, near 14.7, or rich.
but the way a good a/f gauge is supposed to work, is show you with more accuracy what your a/f ratio really is, more like instead of rich, it'll say 10.4, etc.
all your will gauge do at this point is look nice. or rice, however you take it.
a proper a/f gauge will display a number or at least point to a specific number. the lights are just a bonus. and to use such a gauge, you'd need a wideband o2 sensor.
Old Aug 25, 2005 | 11:45 PM
ek_kid's Avatar
Default Re: Air/Fuel Ratio gauges work on b16's ???? (iaredavid)
finally some one can explane something well
Old Aug 26, 2005 | 08:38 AM
Default Re: Air/Fuel Ratio gauges work on b16's ???? (ek_kid)
ok....first it won't work.
Then it works...
Then it works, but not very accurate...
Then it doesn't work
Then is work with only wideband.....
Old Aug 26, 2005 | 08:44 AM
nota-eg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ApolloSpeed &raquo;</TD></TR><TR><TD CLASS="quote">ok....first it won't work.
Then it works...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iaredavid &raquo;</TD></TR><TR><TD CLASS="quote">h-t will do that to you
a proper a/f gauge will display a number or at least point to a specific number. the lights are just a bonus. and to use such a gauge, you'd need a wideband o2 sensor.</TD></TR></TABLE>
Reread what he said.
-The guage you have will give you a basic idea as to whether you are running rich, around 14.7, or lean. No definate number such as "10.78" or "17.21"
-A wideband O2 gives you a definate number in its readout, such as my PLX WB system will read 13.58, 12.48, 11.22, 10.97, ect.
-The sensor you have says it will work with narrowband, meaning it will tell you rich, lean, or stoich; no real tuning numbers.
Old Aug 26, 2005 | 08:45 AM
EG93si's Avatar
get a clue, it works but not accuratly enough to justify getting it. Rice= have it to have it, tuner= have it to use it (acuratly), yes i will diss even though i can't spell
Old Aug 26, 2005 | 08:55 AM
nota-eg's Avatar
Default Re: Air/Fuel Ratio gauges work on b16's ???? (EG93si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG93si &raquo;</TD></TR><TR><TD CLASS="quote">get a clue, it works but not accuratly enough to justify getting it. Rice= have it to have it, tuner= have it to use it (acuratly), yes i will diss even though i can't spell</TD></TR></TABLE>
Sounds like my friend's accord. He has more EBay on his accord than he does Honda/Acura.
Old Aug 26, 2005 | 09:08 AM
Default Re: Air/Fuel Ratio gauges work on b16's ???? (nota-eg)
Ok cool......basically I just wanted the A/F ratio to trouble shoot some problems.....and as a "general" idea of my mixture.
It is cool to know that cause a mix that is way lean or way rich I know will hurt an engine!
So i should just be able to "splice" into my narrow band wires to get it to work for what i'm doing, Right ?
Old Aug 26, 2005 | 09:10 AM
nota-eg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ApolloSpeed &raquo;</TD></TR><TR><TD CLASS="quote">It is cool to know that cause a mix that is way lean or way rich I know will hurt an engine!</TD></TR></TABLE>
So will ******* with things when you have no idea what you're doing *raises hand* "Me me me me!"
Old Aug 26, 2005 | 09:19 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nota-eg &raquo;</TD></TR><TR><TD CLASS="quote">
So will ******* with things when you have no idea what you're doing *raises hand* "Me me me me!"</TD></TR></TABLE>
Be nice, he is only asking questions to learn. Everyone has to start somewhere.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ApolloSpeed &raquo;</TD></TR><TR><TD CLASS="quote">So i should just be able to "splice" into my narrow band wires to get it to work for what i'm doing, Right ?</TD></TR></TABLE>
Yes, but take the readings grain of **** and do not use them for power tuning. The readings are only as good as the 02 sensor.
Old Aug 26, 2005 | 09:22 AM
nota-eg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbogixxer &raquo;</TD></TR><TR><TD CLASS="quote">Be nice, he is only asking questions to learn. Everyone has to start somewhere. </TD></TR></TABLE>
I wasn't trying to be mean to him, I was just letting him know. I've fucked with things on my car that I wish I hadn't because I spend more time figuring out what the **** I screwed up instead of enjoying what I "Fixed".
Old Aug 26, 2005 | 09:23 AM
that's why I'm HERE ! To learn a little I hope
Import_lifestyle
Jun 29, 2006 08:28 AM
finest_GSR
Apr 28, 2006 12:53 PM
vtekstorm
Nov 15, 2004 05:56 PM
mikeaagesen
Jul 13, 2003 02:40 PM
Pompiuses
Jun 12, 2003 04:49 PM
