what does sleeving do?
Old Feb 24, 2002 | 09:03 PM
relic_sypher's Avatar
Default what does sleeving do?
I'm just trying to learn as much as I can about these engines and the modifications available. So could anyone explain what this does. That would be reall great. Thanks!
Old Feb 24, 2002 | 09:31 PM
MugenSi00's Avatar
Default Re: what does sleeving do? (relic_sypher)
it is done for a couple of reasons.
1. to repair a damaged cylinder wall
2. allows the combustion area to handle boost better
Golden Eagle is one of the best out there for honda engines
Old Feb 24, 2002 | 09:45 PM
B18C-EJ1
Guest
Posts: n/a
Default Re: what does sleeving do? (MugenSi00)
One more....
3 - To increase displacement.
Old Feb 25, 2002 | 10:02 AM
B19CivicHB's Avatar
Default Re: what does sleeving do? (B18C-EJ1)
How much does it usually cost to overbore an engine .2L? (1.8-2.0)
Old Feb 25, 2002 | 10:08 AM
B18C-EJ1
Guest
Posts: n/a
Default Re: what does sleeving do? (B18CivicHB)
Sleaving can run as much as $1100.
You can find it for less though.
Old Feb 25, 2002 | 11:08 AM
shamoo's Avatar
Will you make something up for me please?
To just overbore it, it won't be much....like $100-120 or so. But to go all the way from 1.8L to 2.0L reliably, I believe you have to bore it to 85mm or more. That's too much for stock sleeves (too weak). So then you'll have to resleeve it. When you resleeve it, you can go pretty high.
Check out http://www.goldeneaglemfg.com
Old Feb 25, 2002 | 11:11 AM
Spade's Avatar
Default Re: what does sleeving do? (shamoo)
For a d series it cost 750 plus shipping. then another 125 to bore and hone.
Old Feb 25, 2002 | 11:33 AM
B19CivicHB's Avatar
Default Re: what does sleeving do? (Spade)
what about JDM GSR?
fusion645
Dec 31, 2009 08:40 PM
kaj
Sep 16, 2006 09:38 AM
jDMJeRk
Nov 8, 2004 05:01 PM
2ltrsnailpwr
Jun 23, 2003 02:06 PM
dennis
Dec 18, 2002 01:47 AM
