will d16y8 spark plugs fit into b18c1?
Old Aug 25, 2005 | 10:25 AM
crackerjacker006's Avatar
Default will d16y8 spark plugs fit into b18c1?
just what title says
Old Aug 25, 2005 | 11:01 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: will d16y8 spark plugs fit into b18c1? (carjacker006)
these are the specs in the y8 plugs:
14mm thread, 19mm(3/4") reach,16mm( 5/8") hex, extra projected, resistor, double platinum, .044"gap
these are the specs on the gsr plugs:
14mm thread, 3/4" reach, 5/8" hex, gasket seat, ISO length, resistor, projected tip, fine wire (0.6mm) iridium center electrode, tapered cut ground electrode, .044" gap
so the installed height and stuff is the same BUT:
looking at the double platinum plugs on sparkplugs.com,
the stock numbers are different. possible heat ranges are different. they will fit in and may work, but dont hold me to it.
Jimi Hondrix
Jul 19, 2015 05:22 PM
DOUBLExDEUCEx22
Feb 18, 2009 02:43 PM
Jimster480
Dec 31, 2008 08:59 AM
Hazem
11
Dec 7, 2004 04:59 AM
