how do i make a turbo ls quite
Old Aug 25, 2005 | 12:31 AM
Ls-Turbo's Avatar
Default how do i make a turbo ls quite
i am gunna have a Ls turbo.. and i was just wonderin how to make it run quite.. what would i need to have on my piping.. i plan to do 12 psi daily.. with 3in piping
Old Aug 25, 2005 | 01:39 AM
playboyace35's Avatar
Default Re: how do i make a turbo ls quite (j.d.m.ness)
quiet?
Old Aug 25, 2005 | 05:27 AM
Rod.'s Avatar
Default Re: how do i make a turbo ls quite (playboyace35)
i dotn think you can make it run quiet. You dont want to quiet down the spooling, that is the best part.
Old Aug 25, 2005 | 11:19 AM
Sketch_hs's Avatar
make an airbox, or find an oem one that will work. recirc bov. wg dump into exhaust. quiet exhaust system.
boom. quiet. fast. hella sleeper
Old Aug 25, 2005 | 12:42 PM
Ls-Turbo's Avatar
Default Re: (Sketch_hs)
i dont really care about how loud the turbo spools its just the exhuast.. that loud.. which exhuast sounds almost stock
Old Aug 25, 2005 | 12:44 PM
N20civicB18's Avatar
Default Re: (j.d.m.ness)
just run a stock type-r exhaust or something
Old Aug 25, 2005 | 12:51 PM
Ls-Turbo's Avatar
Default Re: (N20civicB18)
that would create to much back pressure.. doin 12lbs on a drag3 kit
Old Aug 25, 2005 | 12:52 PM
1bar's Avatar
open downpipe, its not that bad
Old Aug 25, 2005 | 12:58 PM
jayswift's Avatar
Default Re: (1bar)
your turbo set up is not going to sound the same as your N/A set up. what kind of exhaust are you going to run? 3in piping and a quiet muffler kind of contradicts itself.
Old Aug 25, 2005 | 01:04 PM
TeamYelloHead's Avatar
NA set up and turbo sounds different, a NA with no cat and straight piping sounds like ****, its loud as hell and high pitched, but same set up on a turbo car, sounds deep, mean, loud but not kill my ears loud
Old Aug 25, 2005 | 01:10 PM
Tomakit's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by j.d.m.ness &raquo;</TD></TR><TR><TD CLASS="quote">and i was just wonderin how to make it run quite.. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by N20civicB18 &raquo;</TD></TR><TR><TD CLASS="quote">just run a stock type-r exhaust or something</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by j.d.m.ness &raquo;</TD></TR><TR><TD CLASS="quote">that would create to much back pressure.. doin 12lbs on a drag3 kit</TD></TR></TABLE>
One or the other here...better performance w/ a less restrictive muffler. More sound suppression w/ a more restricted, baffled muffler.
Old Aug 25, 2005 | 01:16 PM
Default Re: how do i make a turbo ls quite (Tomakit)
you sound like you need a stcok exhaust with a e-cut out maybe on a WOT or rpm based switch
Old Aug 25, 2005 | 01:18 PM
new2novas's Avatar
Default Re: how do i make a turbo ls quite (N20civicB18)
get yourslef a greddy sp2, i got it on mine, although NA its real quiet
Old Aug 25, 2005 | 01:22 PM
1boostedcivic's Avatar
Default Re: how do i make a turbo ls quite (new2novas)
reroute wastegate into downpipe, 2 1/2 piping with a resonator.
Old Aug 25, 2005 | 01:26 PM
HiProfile's Avatar
Ask around at local shops, some do custom 3" exhausts for cheap (friend got 3" for $140 for a GTI).
If you want it super quiet, run a 24" resonator (basicly any preforated-tube type glasspack) and any muffler. 24" with a 3" straight-through Magnaflow muffler is deep, yet quiet. If you want others to hear you a little, just run 2 resonators. The turbo essentially acts as a muffler - the heavy cast-iron housing absorbs sound very well.
RedTT
Sep 11, 2004 09:22 AM
blackriceman
May 5, 2004 06:41 PM
94lsboost
Oct 1, 2003 06:13 PM
B18B1DOHC
Sep 16, 2003 10:50 AM
Tru Dynamix
Feb 8, 2003 07:25 AM
