HEad work to a LS
Old Aug 24, 2005 | 09:47 PM
JDMGhosteg-6's Avatar
Default HEad work to a LS
If I get the head cut on an LS what will my Compression ratio be.......should I do this if I want to boost?
Old Aug 24, 2005 | 11:46 PM
iaredavid's Avatar
Default Re: HEad work to a LS (JDMGhosteg-6)
depends on how much you get milled. i'm assuming you're gonna be shaving off the BLOCK and not the head itself... you'll increase compression by shaving.
anyway, for boost you tend to want lower compression, so only mill enough to have a flat deck. if you have to mill alot, you may want to get a thicker head gasket.
Old Aug 24, 2005 | 11:49 PM
ceLtic*
Guest
Posts: n/a
Default Re: HEad work to a LS (iaredavid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iaredavid &raquo;</TD></TR><TR><TD CLASS="quote">depends on how much you get milled. i'm assuming you're gonna be shaving off the BLOCK and not the head itself... you'll increase compression by shaving.
anyway, for boost you tend to want lower compression, so only mill enough to have a flat deck. if you have to mill alot, you may want to get a thicker head gasket.</TD></TR></TABLE>
well said.
uses0ap
Jan 4, 2010 01:34 PM
ProjectBB6
Mar 13, 2008 09:24 AM
allmotorbeasteg6
Aug 25, 2004 12:19 PM
Jun 26, 2004 08:51 PM
prdtr15
Sep 25, 2003 03:45 PM
