Car wont start..........again!
Old Aug 24, 2005 | 08:38 PM
poundedhatchcrap's Avatar
Default Car wont start..........again!
My car cranks all day long and gets fuel but wont start. The main relay clicks as fast as the car cranks and the check engine light stays on. I have no light on my ecu and the car has no spark. Im gonna try a different main realy and see if that dont help. What do u guys think? Any help is great thanks
Old Aug 24, 2005 | 08:41 PM
thumbtack's Avatar
Default Re: Car wont start..........again! (poundedhatchcrap)
With a solid CEL I thought means that the ecu is dead.
check the #14 fuse alternator solenoid or something like that. Test your distributor for resistance should be around 350-700 (not sure on exact numbers) I think according to helms manual.
If a friend has the same ecu though, try swapping it in place of yours and see if it starts. If it does, get a new ecu.
Old Aug 24, 2005 | 08:46 PM
Default Re: Car wont start..........again! (thumbtack)
That fuse is good. I was told to change that fuse by several people. So i did and it didnt change anything. I have 4 ecu's and none of them work. Tried one out of my friends working car and it dont work either. I will try testing the dizzy tonight for resistance though now that i know those numbers. Thanks. Anything else anyone can think of?
Old Aug 24, 2005 | 11:05 PM
2000psi's Avatar
From: We Cant Stop Here This Is Bat Country, So CaL, USDM
1-3-4-2?
Old Aug 24, 2005 | 11:29 PM
C uR eX's Avatar
hmm..try thing..swap out the main relay with a known working one and also if your coil have never been replaced, do that also..cause one of the car that i was working on had the same starting problem and i have tried several option..and sometime it a combination of things that causes to not start..but yeah that my opinion for you to do.
Old Aug 25, 2005 | 02:14 AM
TH33G4MON3's Avatar
wow sounds like a big prob
Old Aug 25, 2005 | 07:00 AM
Duane_in_Japan's Avatar
The main relay is controled through its ground circuit, so if your Honda has the main ECU ground out at the thermostat housing then take it apart and clean it and put it back together, it sounds like the main ground is being tasked while cranking, the ususal sign of a dirty ground connection.
Old Aug 25, 2005 | 02:29 PM
Default Re: Car wont start..........again! (Duane_in_Japan)
Thanks everybody it was the ground on the theromstat. It wasnt cleaned. It runs now thanks for all the help homies!
K i l l a B e e.
11
Sep 1, 2008 01:08 AM
jdmmostwanted
Jan 23, 2008 12:13 AM
dump3deg6
Oct 30, 2007 03:07 AM
