do i need an adjustable fuel pressure reg. if im running walbro 255lph with stock fuel rail on turbo
hey. do i need to run an adjustable fuel pressure regulator on my stock fuel rail on a jdm gsr that im about to turbo. im using a walbro 255lph fuel pump. will i burn it out if i dont increase the fuel flow or somethin. im using 550 injectors also if that helps at all. thanks
I cant really give you a good answer because I dont know.
But i've been running a walbro 255lph with stock fuel rail and fpr on my car for almost 3 years without problems.
Im also running 550cc injectors.
I dont know if its luck or if I should get a fpr too.
you really dont need a fpr until you start to see pressure drop mostly in higher horserpower car that need a 1:1 rising pressure
correct if im wrong anybody
danmej1
Nov 5, 2010 06:33 PM
saer
Jun 3, 2005 04:17 PM
zseeanz
Apr 5, 2004 07:48 AM
