wiring a/f ratio gauge
Old Aug 24, 2005 | 07:30 PM
flipsta27's Avatar
Default wiring a/f ratio gauge
what up all you honda freaks out there. i'm new here, my name is felipe. can someone please tell me which wire to tap in to off the ecu to properly wire an a/f ratio gauge. wire color? pin location? i looked it up on alldata at work but the black/orange wire am tapped in to doesnt seem to work right on the gauge. with the car running @ Idle the leds stay lit red and yellow in between stoich and lean. but they won't switch like it should. oh i have a eg with a obd1 gsr motor (jdm p72), and i have a autometer a/f/ratio carbon fiber face gauge. thanks
Old Aug 24, 2005 | 10:32 PM
RYANR1's Avatar
Default Re: wiring a/f ratio gauge (flipsta27)
All data has been very accurate for me. Double check the wiring and make sure the car is warm and in closed loop or you will not see the o2 sensor switching.
Old Aug 25, 2005 | 02:00 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: wiring a/f ratio gauge (RYANR1)
Should be the white wire i believe... but if you used All Data, its probably correct. Since you don't have a Wideband O2, your gauge is pretty much useless and inaccurate.
hondaaccordf23
Jul 30, 2012 12:24 AM
IntegraType-R
Sep 29, 2008 05:40 PM
nicko360
Mar 7, 2007 03:20 PM
civicnar
Feb 26, 2004 05:22 PM
