Burning Oil HELP
Old Aug 24, 2005 | 06:57 PM
SOHCD16y8's Avatar
Default Burning Oil HELP
A freind of mine has a b18b that we built for his turbo project. We have not boosted on it yet becuase we are still breaking it in all-motor. However It is burning oil bad. Cylinders 1 and 2 are running great, plugs are good and show a healthy burn. However when we pull 3 and 4 they are soaked in oil. Ive built about 6 motors now and have never come across this. Im guessing that the rings on those cylinders were just installed incorrectly, ill find out when I pull it apart for him for sure. But I was wondering if you guys had any other ideas as to why this would happen on 3 and 4 other then coincedence. Maybe because it is on the shallow side of the pan or something random that im not thinking of. I didnt bother to do a compression test beacue I figured the #s would be so inaccurate do to the oil in the cylinders. Thanks in advance for help.
Hard break-in BTW but it was smoking from the moment we started it up.
Old Aug 24, 2005 | 08:11 PM
vaporboy12's Avatar
Default Re: Burning Oil HELP (SOHCD16y8)
do a compression and leak down test. the rings might be all lined up together its hard to tell. no new motor should have any type of oil on the plugs
Old Aug 25, 2005 | 07:11 PM
SOHCD16y8's Avatar
Its a little late for that since the motor is out of the car and I dont have a leak down tester, I should know if the rings lined up soon when I get time to help him out and pull apart the motor. Any other ideas or just coincedence it was 3 and 4. BTW those were the first cylinders he put together ever (this was his first motor)
Old Aug 25, 2005 | 07:21 PM
SOHCD16y8's Avatar
Default Re: Burning Oil HELP (vaporboy12)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vaporboy12 &raquo;</TD></TR><TR><TD CLASS="quote"> no new motor should have any type of oil on the plugs</TD></TR></TABLE>
Thats the main reason I asked, Im just confused as to why 1 and 2 would run so perfect when 3 and 4 are fucked. I just wanted to make sure there wasnt some crazy thing going on in the motor or then poorly installed rings
Old Aug 27, 2005 | 03:07 PM
SOHCD16y8's Avatar
One more bump, anyone?
shotgun2224
Honda S2000
12
Feb 13, 2009 11:38 PM
Powelly
12
Sep 5, 2008 09:54 AM
Old_Honda
Apr 5, 2005 08:25 PM
hachirokulude
Jul 18, 2004 06:04 PM
Layziebtnh055
Jun 22, 2004 03:25 PM
