2 Problems here: And yes I have searched.......
Yes, I have searched and found nothing. My problems: 1: The Honda DX that I juts bought did not have a Fuse cover with it so I have no idea what are the correct fuses to be putting in. 2: While installing my cd player, I accedently touched the red wire to ground and the Dome light and the beeping noise when the keys are installed Does NOT work anymore, This leads back to problem #1 I Dont know what fuse is the dome light/beeping noise, But I checked EVERY fuse and not one is blown. But the Radio works..... Can someone please give me a print out of the fuse cover so I can try to figure out what are the correct fuses to put in. Is there a way to test each fuse? I used a test light, only like 5 fuses lit up.
I have that diagram. send me an email and I will send a PDF of the fuse box and circuit designations.
It is circuit #3 a 7.5 amp fuse, third fuse from the left, bottom row (note there is a spare fuse slot in the far left location so it may appear to be the 4th from the left bottom row). It the only 7.5 Amp fuse on the bottom row.
It is easy to identify a blown fuse the little "S" shaped wire in the plastic housing will be burnt in half. Look a t a good one and compare it to a suspected bad one.
Modified by tpr at 8:49 AM 8/25/2005
Modified by tpr at 8:50 AM 8/25/2005
NACvicSi
Aug 27, 2009 05:03 PM
