tarnished flywheel surface pics inside
ok well i touch the mating surface of my flywheel when i recieved it and now about a week later i opened the box and its trnished. Iv tried brake and carb cleaner to remove it and rubing but it wont come off. Is it ok to install?
Its just surface rust from sweat/oils from your finger. I'd clean it with alcohol and then install it, when you use the clutch it'll "grind" it off.
bboylito
Jul 19, 2005 12:17 AM
