Clutch Issue once again. Help !
Old Aug 24, 2005 | 12:42 PM
Rocks.'s Avatar
Default Clutch Issue once again. Help !
Well my clutch is still acting up and I have some more symptoms for you guys. First of all the clutch does not slip at all its a ACT HDSS W/ ACT STREET FW but there are some wierd things going on such as; when I leave the car alone for the night and try to leave the following day the clutch wont engage unless I pump the clutch pedal then sometimes the pedal gets stuck on the way back up. I dont want to replace both the master cylinder and the clutch so what would you think would be the culprit. Thank you.
Old Aug 24, 2005 | 12:48 PM
1.8EG-T's Avatar
Default Re: Clutch Issue once again. Help ! (Kobester)
Bleed you hydro system first. If that does not work then look inside your car under your dash for master cylinder leaks.
Old Aug 24, 2005 | 01:56 PM
Jimmy's Avatar
Global Moderator
Default Re: Clutch Issue once again. Help ! (1.8EG-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1.8EG-T &raquo;</TD></TR><TR><TD CLASS="quote">Bleed you hydro system first. If that does not work then look inside your car under your dash for master cylinder leaks.</TD></TR></TABLE>
Also could possibly be a bad clutch slave cylinder
PaulMc
May 18, 2014 05:04 PM
beanwagon
Dec 12, 2008 02:55 PM
JimmyAtlantis
Jun 2, 2006 08:55 AM
s1ngle
13
Sep 21, 2005 12:01 PM
FLCivic
Jun 30, 2004 03:48 PM
