car feels like its bogging at 5k rpms
Old Aug 24, 2005 | 12:24 PM
crackerjacker006's Avatar
Default car feels like its bogging at 5k rpms
I swapped a b18c1 into my civic about a month ago. Its basically stock but i have noticed that beween the vtec engagement to about 6k rpms it really seems like it struggles a little. Almost like it might be getting too much fuel. Before vtec and after 6k it feels fine and pulls hard its just that right after vtec engages you cant tell much of a difference except for the noise. I do have a vafc and i plan to get it hooked up soon and i will prolly take it to the dyno. Do you guys think that this problem may be fixed by having the motor tuned up? or could this be another problem?
Old Aug 24, 2005 | 12:41 PM
E46Kid's Avatar
bump for this cause i wanna know 2 for my b16a2..it also bogs when i kick on vtec
Modified by 94VtecEG at 4:58 PM 8/24/2005
Old Aug 24, 2005 | 02:51 PM
Default Re: (94VtecEG)
bump again
Old Aug 24, 2005 | 03:11 PM
domestic abuser's Avatar
Default Re: car feels like its bogging at 5k rpms (carjacker006)
Does it bog under the same load at 5gs or not? Not sure, but you're probably just running a little rich. However, I swapped the same motor in my civic and unlike the B16, the GSR doesnt really have much of a v-tec spike thats really noticeable, but once your secondaries open, youre gone. Get it tuned and lean it out and im sure you will be much more pleased.
Old Aug 24, 2005 | 03:23 PM
Default Re: car feels like its bogging at 5k rpms (durtydavey)
yea it feels like it is running rich right as vtec engages as soon as i get the type r cams im gonna have it tuned on a dyno and hopefully that will fix it
Old Aug 24, 2005 | 07:30 PM
good luck and let us know how it goes
Old Aug 24, 2005 | 07:34 PM
ABK's Avatar
ABK
do you have an exhaust on it? Any restrictions. There was a thread awhile ago about this guy coming back from the dyno and trying to drive around with a gay silencer on his exhaust. His car would like missfire when vtec engaged, and started pulling after 6 grand. Check your cat, or just try to run open header.
If that's no the case, do a tune up. See if any plugs are fouled out. Change your fuel filter. Any other mods on the car?
Old Aug 24, 2005 | 07:37 PM
SirRevvs's Avatar
Default Re: car feels like its bogging at 5k rpms (ABK)
Stock Computer? Which one are you using? What mods? You could have a bad TPS or FPR if your running a stock computer (if its a P72 or P30).
Old Aug 24, 2005 | 07:43 PM
ABK's Avatar
ABK
Default Re: car feels like its bogging at 5k rpms (SirRevvs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SirRevvs &raquo;</TD></TR><TR><TD CLASS="quote">Stock Computer? Which one are you using? What mods? You could have a bad TPS or FPR if your running a stock computer (if its a P72 or P30).</TD></TR></TABLE>
if it's not a gsr computer it's defently your problem, lol. You can't getho rig it. VAFC should be set to default if it is a stock engine. Plus only gsr and h22 ecu will make secondaries open, unless it's an uberdata or hondata. If it's not a gsr ecu sell your VAFC and get one.
Old Aug 24, 2005 | 07:50 PM
SirRevvs's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ABK &raquo;</TD></TR><TR><TD CLASS="quote">
if it's not a gsr computer it's defently your problem, lol. You can't getho rig it. VAFC should be set to default if it is a stock engine. Plus only gsr and h22 ecu will make secondaries open, unless it's an uberdata or hondata. If it's not a gsr ecu sell your VAFC and get one.</TD></TR></TABLE>
Even if the secondaries don't open, it wouldn't cause it to bog. I've ran my B18C1 with secondaries always closed, and always open. Sounds like a fuel problem.
Old Aug 24, 2005 | 07:58 PM
ABK's Avatar
ABK
Even if the secondaries don't open, it wouldn't cause it to bog. I've ran my B18C1 with secondaries always closed, and always open. Sounds like a fuel problem. And you can use any VTEC computer it doesn't have to be a P72. Any old P28 (easy to find) can be socketed, and reprogrammed very easily to run a DOHC VTEC engine.</TD></TR></TABLE>
yeah it can be, that's why I said if not a uberdata or hondata or etc. But I think it is a restriction problem. Either fuel, intake flow, or exhaust flow. Another option is that somebody fucked with a VAFC trying to "tune" the car.
Old Aug 24, 2005 | 08:14 PM
ETA_Si's Avatar
good luck
Old Aug 24, 2005 | 08:20 PM
E46Kid's Avatar
so suggestions would be change the fuel filter?
Old Aug 24, 2005 | 08:21 PM
ABK's Avatar
ABK
you need to post up your set up. The answer could be in there. People do some wild **** sometimes.
Old Aug 24, 2005 | 08:27 PM
E46Kid's Avatar
im runna stock ecu and stock b16a2 on a 2000 si coupe it does bog.. when i kick in vtec at 5500 rpms itlll be like a half second bog..then go..
Old Aug 24, 2005 | 08:35 PM
SirRevvs's Avatar
yeah it can be, that's why I said if not a uberdata or hondata or etc. But I think it is a restriction problem. Either fuel, intake flow, or exhaust flow. Another option is that somebody fucked with a VAFC trying to "tune" the car.</TD></TR></TABLE>
I don't think the VTAK controller is hooked up yet
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carjacker006 &raquo;</TD></TR><TR><TD CLASS="quote">....... I do have a vafc and i plan to get it hooked up soon and i will prolly take it to the dyno. Do you guys think that this problem may be fixed by having the motor tuned up? or could this be another problem?</TD></TR></TABLE>
Old Aug 24, 2005 | 08:53 PM
ABK's Avatar
ABK
oh nevermind then. yeah people with stock exhaust (especially with a cat on) try open header. my friends b16 wasn't running to good until cat got hollowed out.
then fuel problems.
Then It could have something to do with oil pressure problems too but that's the last thing to check.
Old Aug 24, 2005 | 09:13 PM
SirRevvs's Avatar
then fuel problems.
Then It could have something to do with oil pressure problems too but that's the last thing to check.</TD></TR></TABLE>
If the oil pressure was low VTEC wouldn't work
Old Aug 24, 2005 | 09:16 PM
ABK's Avatar
ABK
yeah the problem is that once vtec kicks in you loose little bit of the oil pressure.
Old Aug 25, 2005 | 10:06 AM
heres my setup
-96 usdm b18c1
-stock gsr ecu p72
-crappy intake
-apexi cat back exhaust
-cheap obx header
and i have a vafc but it isnt hooked up
Its been like this since i got the motor but its not to noticeable, i do notice a more gradual pull in my brothers gsr integra but mine doesnt feel too powerful until 6k. It also smokes kinda heavily when you floor it (not too bad but you can see it a little in the mirror). I will check the spark plugs and fuel filter today, are d series spark plugs the same for the b18? cause i just put new spark plugs in it before i swapped them.
Old Aug 25, 2005 | 12:15 PM
smoking now? How much? Im curious now. If you know someone who can mock up a leakdown and compression test cheap, Id do it just to be sure your looking in the right place and if not then just to check. Mine used to be basically the same you describe it, and I tested and found out the major problem(s).
Old Aug 25, 2005 | 03:17 PM
JDMHatch95si's Avatar
I have this same exact problem as well , and i cant figure it out . Car runs very rich here is my setup
JDM B16A
GSR ecu
aem sri
skunk2 cat-back
dc sports header
no-name hi-flow cat
it runs fine up to about 5000 then vtec kicks in and the pull is just nowhere near as hard as it used to be ....... talked to a honda mechanic and he suggested the PCM . Any opinions on this ?
es_squared
Jul 14, 2009 07:35 PM
bmacc
Honda Civic (2001 - 2005)
12
Jul 26, 2007 05:10 PM
Don Jefe
Sep 3, 2006 12:42 PM
apgarabu
May 25, 2005 06:15 AM
