Started motor with wratchet on crank pulley
Old Aug 24, 2005 | 12:19 PM
88 rex's Avatar
Default Started motor with wratchet on crank pulley
I did something stupid. I was adjusting the tension on my B18 and I had the wratchet on the crank pulley bolt when i went to start the motor b/c my father stopped by to take a look. The wratchet shot out from under the car and now now i have a rattling sound coming from somwhere around the tensioner and water pump. I haven't taken off the bottom plastic cover to actually look at the tensioner, but what kind of damage could i have caused? I pulled the valve just to take a peak and everything looks ok.
What could be causing my rattling sound? I'll probably just buy a new tensioner, belt, and water pump b/c it's about time to be replaced, but what else could i have messed up?
<<<-----Idiot
Old Aug 24, 2005 | 12:24 PM
soulkeeper's Avatar
Default Re: Started motor with wratchet on crank pulley (88 rex)
......ROFL, sry, but its just funny cuase i do that all the time, it makes you pee your pants cuase it sounds like the freaking motor blew up..
ive never had anything break though becuase of it, you might wanna torque your crank pully down though, it might of losend the bolt.
Old Aug 24, 2005 | 01:44 PM
VegasEFHB's Avatar
WOW !
I thought I was a dork! No offense meant, but reading this brightened my day immensely! Check your WP and crank pulley, and make sure it is all tightened to spec.
Keep up the good work
Old Aug 24, 2005 | 03:33 PM
Voodooboy520's Avatar
if theres rattling, something could have broken off inside, or the wratchet could've put a hole in the timing belt cover. just a guess.
Old Aug 24, 2005 | 06:16 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: (Voodooboy520)
I did that before on my crx, I had the wheel off and it shot out the side and made two dents in the side of the car. I felt so dumb.
Old Aug 24, 2005 | 06:21 PM
trrbl1bmx's Avatar
that is pretty funny. but i hope you didnt screw up anything major.
Old Aug 24, 2005 | 07:34 PM
migizzel's Avatar
Default Re: (ilovemyef9)
i would check that crank bolt could be possible that u loosen the tensioner or got the spring out of its place and it got on the bottom of ur belt cover just my 2 cents
Old Aug 25, 2005 | 03:30 AM
88 rex's Avatar
Default Re: (migizzel)
Well, I feel better in knowing that i'm not the only one who's done this before and I'll take a look at everything mentioned.
Thanks
Old Aug 25, 2005 | 05:06 AM
jadkar's Avatar
Hmmm....I can't see this damaging anything. The engine should be able to take that abuse, that's why the cover is there in the first place.
My first guess is something (either dirt, crud, or plastic) broke off from inside the cover and is bouncing around inside the cover. There are a couple of little plastic spacers that are molded into the cover, maybe one of those broke off.
How about the spring breaking on the tensioner?? Maybe the shock was enough to break it or throw it off the attaching pin. If the tensioner was tightened already everything would still be OK and the spring could just be bouncing around.
Also, give us a little better description of the rattle. Does it sound metalic or plastic? Is it a rubbing sound or a jingling (loose change noise)
Damn this sucks though, to get behind the covers you have to take the crank pulley back off and I don't want to even think how difficult that is once that big engine is in the car. Do you even have clearance to slide it off? Also, be thankful the ratchet didn't fly up and hit your nice carbon hood!!
PS...I hate when people interupt me when I'm wrenching
Old Aug 25, 2005 | 07:52 PM
88 rex's Avatar
Default Re: Started motor with wratchet on crank pulley (jadkar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jadkar &raquo;</TD></TR><TR><TD CLASS="quote">Hmmm....I can't see this damaging anything. The engine should be able to take that abuse, that's why the cover is there in the first place.
PS...I hate when people interupt me when I'm wrenching </TD></TR></TABLE>
Welcome to H-T!!
But, yea, spring looks good and the tensioner is tightened down. I'm going to wait to run it again until i get my exhaust on to help lower the noise leve to concentrate solely on the rattle.
But yea, changing the belt looks like a piece of cake while its still in the car. Crank pulley is easily accesible and all you'll have to do is remove the driver side mount. Surprisingly, there is plenty of room (I also don't have any of the plastic around my radius rods or the front, but neither will you when you put your full race on )
Old Aug 25, 2005 | 08:35 PM
TH33G4MON3's Avatar
that makes my night right there thank you! haha I havn't experienced that yet so I'm no help sorry
Old Aug 25, 2005 | 09:14 PM
biggdogg's Avatar
Default Re: Started motor with wratchet on crank pulley (TH33G4MON3)
i do it all the time . on my car and everyone elses. check your plastic liners in the fender wells and the crank pulley torque.
jlfrnce
Dec 4, 2009 07:48 PM
Bac91Da
May 30, 2008 04:14 PM
burgboy73
Nov 17, 2006 02:01 PM
geldingmakr
Aug 3, 2004 10:51 AM
Tad
12
Feb 9, 2004 05:13 PM
