shifting with out clutch????
Old Aug 24, 2005 | 09:50 AM
Cypher0117's Avatar
Default shifting with out clutch????
I was dropping a friend off at his house a couple of nights ago and the car wasn't moving or on. The parking brake was on and i left the car in 1st gear. He was getting out and forgot something so i leaned over to the passenger side to give it to him and i bumped the shifter and it came out of first into neutral. The clutch was still engaged. Withouth thinking i put it back into gear without pressing the clutch in and then realized the clutch was never disengaged while shifting. Is this normal??? idk much about how a manual trans is supposed to work while the car is off and stationary
Old Aug 24, 2005 | 09:52 AM
BeanBag64's Avatar
Default Re: shifting with out clutch???? (Cypher0117)
Yeah its normal. End of thread.
Old Aug 24, 2005 | 09:57 AM
civboy115's Avatar
you didnt "shift". You just put it in gear while the car was off. haha try doing that when the car is running and itll be a different story.
now, end of thread.
Old Aug 24, 2005 | 10:03 AM
IHateJDM's Avatar
Default Re: shifting with out clutch???? (civboy115)
you can shift without the clutch while the car is running if your timing is good. Do not run out and try this though, as you can cause damage to the tranny if you don't know what you are doing.
Now end thread.
Old Aug 24, 2005 | 10:06 AM
civicEXtreme's Avatar
lol, I love how everyone is saying the same thing.
Old Aug 24, 2005 | 11:30 AM
EJ8VTEC's Avatar
Mr. Indecisive
Default Re: (civicEXtreme)
Not the same thing... when it is off it will do it no prob, when it is running with the proper rpm and timing it can be done
end of thread
Old Aug 24, 2005 | 11:36 AM
dirtyracer's Avatar
shifting through gears with the car off doesnt really hurt anything
shift wth the car on, and you get that un bearable noise of your gears grinding to pieces. i have the same kind of car and everythng don it plenty of times
Old Aug 24, 2005 | 12:26 PM
EJ8VTEC's Avatar
Mr. Indecisive
Default Re: shifting with out clutch???? (dirtyracer)
damn u dirty ricer u dont understand, if ur good wit it u can shift without the clutch without hurting the gears, now the synchros n berrings are a totally different story
Old Aug 24, 2005 | 12:39 PM
BeanBag64's Avatar
Default Re: shifting with out clutch???? (EJ8VTEC)
I really wanted this thread to end at me haha.
Old Aug 24, 2005 | 01:04 PM
Jimmy's Avatar
Global Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ8VTEC &raquo;</TD></TR><TR><TD CLASS="quote">damn u dirty ricer u dont understand, if ur good wit it u can shift without the clutch without hurting the gears, now the synchros n berrings are a totally different story</TD></TR></TABLE>
Alright dumbass, why the **** would you want to shift your car without using the ******* clutch while it's running, as i see your signup date i see a newb.. theres no reason why you should be disrespecting other members due to the fact you have no say so..
Thanks
Old Aug 24, 2005 | 01:10 PM
IHateJDM's Avatar
Default Re: shifting with out clutch???? (Jimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">
Thanks</TD></TR></TABLE>
He was just saying that you can shift without the clutch since an earlier post alluded to the fact that you can't. Granted, he did it in a demeaning way, but no more demeaning and unnecessary than your post. Its amazing that even a topic as simple as this can cause an argument. Just let this thread die, there is no more tech in it.
Old Aug 24, 2005 | 01:14 PM
Jimmy's Avatar
Global Moderator
Default Re: shifting with out clutch???? (IHateJDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IHateJDM &raquo;</TD></TR><TR><TD CLASS="quote">
He was just saying that you can shift without the clutch since an earlier post alluded to the fact that you can't. Granted, he did it in a demeaning way, but no more demeaning and unnecessary than your post. Its amazing that even a topic as simple as this can cause an argument. Just let this thread die, there is no more tech in it.</TD></TR></TABLE>
Nor am i the one who started the arguement, i'm sick of new ******* coming in this forum.. making stupid *** threads to begin with & disrespecting people period.
Old Aug 24, 2005 | 01:37 PM
BeanBag64's Avatar
Everyone but me is at fault
Old Aug 24, 2005 | 02:44 PM
nojoke's Avatar
If your slave cylinder or clutch master cylinder goes dead and you insist on driving it, clutchless shifting can get you home just fine...
You have to time it PERFECTLY though, or you will hear a grind.
stuck_in_the90s
23
Aug 10, 2009 08:03 AM
MiraiZ
Aug 12, 2003 06:18 PM
NewUsedGSRowner
Mar 26, 2003 08:31 AM
garados
Oct 19, 2002 07:13 AM
