d15b... Any sensors different from VX other than o2?
My friend just bought a hatch with a d15b vtec in it.
1. The harness they used was all mickey moused up.
2. It was running 440's and uberdata with a turbo base map, yet was not turbo so its running rich as hell.
So we decided to change the harness and computer. I gave him the harness of one of the VX's laying around the shop. Now were getting codes for IACV and TPS. I checked all the plugs and there all right... So any differences between the two?
d15b what? just a jdm d15b? Well i know that the jdm motors do not have a map sensor on the throttle body, so you gotta get one of the firewall mounted map sensors. I had this problem when wiring up a jdm b18b w/ a usdm harness..
another thing is the vx wiring harness wouldn't be wired up for vtec.... check to see if you plugged the tps sensor w/ the map sensor plug. or something..
anyway, after plugging it all up are there any unused plugs left over?
MR.johnson
12
Apr 27, 2008 06:10 PM
