CHANGING A GAUGE CLUSTER
Old Aug 24, 2005 | 09:20 AM
Curbow_USMC's Avatar
Default CHANGING A GAUGE CLUSTER
i have a 99 civic DX and i need a tach but i dont like the big ones on the dash. So i am going to buy a gauge cluster from a EX or SI. I am wonering if it will plug in or will i have to wire it in?
Old Aug 24, 2005 | 09:21 AM
AutoXer's Avatar
Default Re: CHANGING A GAUGE CLUSTER (Curbow_USMC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Curbow_USMC &raquo;</TD></TR><TR><TD CLASS="quote">it will plug in </TD></TR></TABLE>
Old Aug 24, 2005 | 09:22 AM
JDM-97CX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Curbow_USMC &raquo;</TD></TR><TR><TD CLASS="quote">i have a 99 civic DX and i need a tach but i dont like the big ones on the dash. So i am going to buy a gauge cluster from a EX or SI. I am wonering if it will plug in or will i have to wire it in?</TD></TR></TABLE>
It will plug right in.
Old Aug 24, 2005 | 09:33 AM
cre18's Avatar
Default Re: CHANGING A GAUGE CLUSTER (JDM-97CX)
plug and play
Old Aug 24, 2005 | 09:35 AM
SkoundrelUSA's Avatar
cute little bastard
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cre18 &raquo;</TD></TR><TR><TD CLASS="quote">plug and play </TD></TR></TABLE>
Any dumbo can do it. Including me
Old Aug 24, 2005 | 09:54 AM
Cypher0117's Avatar
i bought a tach that was only like 2inch diameter or somthing like that. Was too lazy to change the cluster.
Old Aug 24, 2005 | 11:39 AM
808_si's Avatar
changing the cluster is easy as pie. screwdriver and 10 minutes, you're done. the plugs are color matched as well as size matched so you can't mess it up.
Old Aug 24, 2005 | 11:43 AM
JDM-EJ1's Avatar
Yes, it's going to work.
Old Aug 24, 2005 | 01:19 PM
Default Re: CHANGING A GAUGE CLUSTER (JDM-EJ1)
ok, i just did not know if the plug in was threr because in the DX thier is not tach
Old Aug 25, 2005 | 02:42 PM
i did it and it worked!
thanks,
Old Aug 25, 2005 | 05:13 PM
JDM Vision's Avatar
Default Re: CHANGING A GAUGE CLUSTER (cre18)
eg6civic1538
May 2, 2007 09:57 PM
ek_Tart
Mar 17, 2007 08:42 AM
mikeycivic
13
Feb 16, 2007 12:24 PM
robs93civic
Apr 12, 2006 08:39 PM
Libertariat
Oct 20, 2005 07:36 AM
