general turbo D16 specs
Old Aug 24, 2005 | 08:35 AM
Btothe3rdDegree's Avatar
Default general turbo D16 specs
hey guys i thought it would be nice to get a spec list of the turbo D16's on here so people can look at it to judge there setups. i know i always wonder if my oil pressure is good or if my egts are alright
so here is mine
EGT
idle-800
cruising-1000
WOT-1400-1500
OIL PRESSURE
idle-10/15
cruising 10/15 pounds higher then rpm
WOT- 70/80
VAC/BOOST
idle- 15/20 vac
cruising- 10/5 vac
WOT- depends
AFR
idle- 14.5/15
cruising- 14.5/15
WOT- 12.5/12
i am running 9.1 to 1 pistons, with 10w 40 motor oil, compression checks is right around 150/160. gas mileage is 25 miles to a gallon city, 30/35 miles highway
post your specs
Modified by Btothe3rdDegree at 11:00 PM 8/24/2005
Old Aug 24, 2005 | 02:00 PM
Default Re: general turbo D16 specs (Btothe3rdDegree)
bump
Old Aug 24, 2005 | 05:55 PM
no one else?
Old Aug 24, 2005 | 07:34 PM
1point5CRX's Avatar
ill post mine when i get it all finished
Old Aug 29, 2005 | 04:58 PM
Default Re: general turbo D16 specs (1point5CRX)
no one?
Old Aug 29, 2005 | 05:03 PM
BigMoneyP's Avatar
oil pressure at startup 80psi, idle 10-15psi, WOT 80psi with stock d16turbo and low compression in one cylinder.
Old Aug 31, 2005 | 06:06 PM
Default Re: general turbo D16 specs (BigMoneyP)
no one else
Old Aug 31, 2005 | 08:00 PM
USDM 4G VTEC's Avatar
ok here are mines
EGT
idle-??
cuisin-??
WOT-??
Oil pressure (full warm)
idle-10psi and about 7 psi when really hot
cruising- about 10psi per 1k rpms
WOT- around 50psi
Vacum
idle- 17inhg
cruising-10-inhg
WOT-11psi
AFR
idle- ??
cruising-??
WOT- 12AFR's
turbo D16Z6, 9:0.1 compression, 14B turbo, valvoline 20-50w wich i am going to change to castrol 20-50w
Old Oct 11, 2005 | 02:19 PM
Firstoost's Avatar
Default Re: (USDM 4G VTEC)
how do i nee to set my FMU when i bolt up my turbo its d16z6. and any other little modifications like the oil feed line, oil return assembly and bypass valves
ares650
Oct 2, 2004 04:13 PM
LSVTEC 91 Civic
May 25, 2004 05:56 PM
wade
May 16, 2004 11:08 PM
