What am I missing for my LS/Vtec Conversion!
Old Aug 24, 2005 | 07:56 AM
Maroonda9's Avatar
Default What am I missing for my LS/Vtec Conversion!
I have:
GSR Head
P72 Timming Belt
GSR oil pump
GSR oil pump
B16 Pistions
What Im ordering
Golden Eagle Conversion Kit
ARP Head bolts
Now what elese do I need.
What rings should I use, cause the bottom end Im using is already assembled with the b16 pistions. But I have to change the rings cause when the idiots installed it, they were in a rush and crush an oil ring.
Please get back to me, anyone feel free to help out. Thanks
Old Aug 24, 2005 | 01:39 PM
unknown0001's Avatar
Default Re: What am I missing for my LS/Vtec Conversion! (GetLow93)
Just use the b16 piston rings
Old Aug 24, 2005 | 08:43 PM
lsvtecracer's Avatar
Default Re: What am I missing for my LS/Vtec Conversion! (Mr.RHTuner)
If it's the stock bore then you can used the b16, ls, or gs-r piston rings. As long as it standard bore and have never been bore out then any of the above mention rings should work since they are all 81mm bore.
Old Aug 25, 2005 | 06:26 AM
Maroonda9's Avatar
Default Re: What am I missing for my LS/Vtec Conversion! (lsvtecracer)
what if I hone the bores just to clean them up. Am I gonna have to use bigger rings? Also I want to mic and build it right (using the correct tourqe specs on everythig) can you guys point me in the correct direction for that?
Old Aug 25, 2005 | 04:02 PM
RudeBwaiSi's Avatar
Get headstuds instead of bolts. Get the Endyn breather kit. Sounds like you on the right track.
Old Aug 25, 2005 | 07:24 PM
Maroonda9's Avatar
Default Re: (RudeBwaiSi)
do you know where I can find this stuff onilne?
Old Aug 25, 2005 | 10:14 PM
RudeBwaiSi's Avatar
Search https://honda-tech.com
tougel
Nov 3, 2008 05:59 AM
pokmijn
Oct 5, 2008 05:16 PM
crxowner
Mar 1, 2007 05:23 PM
Importordomestic
Jan 2, 2006 07:18 AM
LsVtEcCrX0515
Sep 28, 2005 10:19 AM
