blowing puffs of smoke when shifting...
Old Aug 23, 2005 | 07:19 PM
mike93eh
Guest
Posts: n/a
Default blowing puffs of smoke when shifting...
whenever im really getting on it and shifting hard i notice big puffs of smoke come out. i dont think it is oil. could it be fuel? i have the greddy z6 kit and im actually running 1 psi more than the stock 5.5 so could it still be rich? i havent messed with emanage yet so are the maps that come on there for the z6 kit just set to run rich?? thats what ive heard. its not coolant because its a blackish greyish color. its not oil because the following are brand new...
head gasket
intake gasket
exhaust gasket
dizzy o ring
valve stem seals
camshaft seal
rear main seal
oil pump seals
oil pan gasket
piston/oil rings
its always done it since ive installed the kit brand new so its not bad turbo seals.
Old Aug 23, 2005 | 07:24 PM
2k.civic.si's Avatar
Default Re: blowing puffs of smoke when shifting... (mike93eh)
you need a wideband to tell if your running rich or not....i had a similar problem and it was the valve seals that caused it
Old Aug 23, 2005 | 07:30 PM
mike93eh
Guest
Posts: n/a
Default Re: blowing puffs of smoke when shifting... (2k.civic.si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2k.civic.si &raquo;</TD></TR><TR><TD CLASS="quote">you need a wideband to tell if your running rich or not....i had a similar problem and it was the valve seals that caused it</TD></TR></TABLE>
well its the stock emanage that comes with the kit so if anyone that has it knows anything about it....
not the valve seals for me. EVERY seal, gasket, whatever has been replaced on this engine. like brand new. it only has 40k miles on it.
and wish i could get a wideband but since they are so damn expensive i have a feeling i wont see one until next year.
Old Aug 23, 2005 | 07:31 PM
mike93eh
Guest
Posts: n/a
oh yea its not blow by either, i have a catch can.
but im pretty sure it is fuel..
Old Aug 24, 2005 | 09:16 AM
mike93eh
Guest
Posts: n/a
hmmm
Old Aug 24, 2005 | 02:21 PM
mike93eh
Guest
Posts: n/a
no one has a greddy kit??
Old Aug 24, 2005 | 02:49 PM
N20civicB18's Avatar
Default Re: (mike93eh)
the color you are discribing sounds like it is fuel
Old Aug 24, 2005 | 02:50 PM
mike93eh
Guest
Posts: n/a
yes but why? im kind looking for other people with the greddy kit on the stock maps...
Old Aug 24, 2005 | 10:07 PM
Maxime's Avatar
You're running too rich.
Old Aug 24, 2005 | 10:26 PM
eMpAtHy's Avatar
Default Re: (Maxime)
black is usually fuel. look at all the cars in japan. they all backfire and shoot out black smoke. it just helps with detonation, but u lose some power. i guess they dont like to put holes in places that dont belong
Old Aug 25, 2005 | 09:18 AM
mike93eh
Guest
Posts: n/a
i guess they pretuned it to be very conservative.. i even turned the psi up. i hear alot of people run upto 10psi fine with teh stock maps that come with the greddy z6 kit and emanage.
Old Aug 25, 2005 | 09:50 AM
vaporboy12's Avatar
it unburnt raw fuel. your running rich. time to get some really magamnet and tuning
Old Aug 26, 2005 | 10:45 PM
92-LS-Civic's Avatar
Default Re: (vaporboy12)
I have a friend with the same problem. Except it smoke not only at full throttle, it smokes at start up, just moving and it blows smoke basically... Its not Oil, it doesnt go through any oil. He is running AFC.
tonytran212002
Aug 29, 2011 07:47 PM
that1kidjr
Jun 15, 2011 03:56 PM
Sketch_hs
26
Sep 3, 2006 06:42 AM
ex voto
11
Oct 2, 2005 01:16 PM
vtec-adykt
10
Sep 16, 2005 07:59 AM
