Can idle be smoothed out by adjusting the ignition timing?
My H23 engine requires 15 degrees advanced at 700 rpm.
As a general rule, is there any way to adjust timing from this default setting to make the idle a bit smoother? (ie, less vibration on the steering wheel at idle)
