auto transmission compatability
Old Aug 23, 2005 | 02:58 PM
douglaslovin's Avatar
Default auto transmission compatability
stupid question, i searched but i think i suck at searching.. and you rarely ever see anybody talking about automatics here.
My d15 has an Auto Tranny in it.. the car im pulling the other d15 out of and rebuilding is manual..
will i be able to drop the d15 from the manual into the one that is automatic?
Modified by douglaslovin at 4:09 PM 8/23/2005
Old Aug 23, 2005 | 03:02 PM
HBK's Avatar
HBK
Default Re: auto transmission compatability (douglaslovin)
alrite, first of all what the hell is a b15 son? Are you talking about your d15 engine with automatic tranny? If you want to replace the automatic trannny with a 5speed, you have to run a 5speed pedal assembly, clutch cable, and install shift linkage in place of the slush box automatic shifter, not to mention run a 5speed dx ECU.
Old Aug 23, 2005 | 03:10 PM
Default Re: auto transmission compatability (HBK)
sorry d15
no im keeping mine automatic. just wondering if the engine from a manual car can be dropped in a car with an automatic tranny... keeping it auto.
Modified by douglaslovin at 4:23 PM 8/23/2005
Old Aug 23, 2005 | 03:32 PM
CRX_Control's Avatar
yeah you can use the manual engine as a build , just make sure you use the automatic intake manifold .
Old Aug 23, 2005 | 04:33 PM
Default Re: auto transmission compatability (CRX_Control)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX_Control &raquo;</TD></TR><TR><TD CLASS="quote">yeah you can use the manual engine as a build , just make sure you use the automatic intake manifold .</TD></TR></TABLE>
awesome man. thanks.
i got most of the engine pulled out of the manual and im gonna get it cleaned up. ill let yall know how it goes when i drop it in my auto
Old Aug 23, 2005 | 04:43 PM
drdisco69's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX_Control &raquo;</TD></TR><TR><TD CLASS="quote">just make sure you use the automatic intake manifold .</TD></TR></TABLE>
Just a dumb question for my own info, but why? I'm not doubting you, just wondering the difference. I'm sure it's blindingly obvious...
Old Aug 23, 2005 | 07:23 PM
silentdork818's Avatar
Default Re: auto transmission compatability (drdisco69)
The automatic manifold has an EGR valve, while the manual manifold does not. If you run without EGR, youll start throwing codes.
Old Aug 23, 2005 | 07:55 PM
drdisco69's Avatar
Default Re: auto transmission compatability (ef four door)
Duh, thank you. I knew it was obvious...
uenolove
Feb 27, 2008 04:32 PM
hany
12
Apr 21, 2007 12:43 AM
DetroitPOScivic
Jun 29, 2004 05:39 PM
KevronsEG
30
Oct 17, 2002 01:26 PM
Mrfirefox
Jul 23, 2002 08:20 AM
