My Car smokes When i reach Redline
It doesn't get to totally over heated but the temperature does go up when i stop completely,Sometimes not all the times...But the white smoke happens all the time when i reach redline...
What do you mean check the Cooling System...what do i ahve to check in the cooling system...They told me to check the spark plugs and i did..its not that...It just throws alot of white smoke when i get to high RPM's..
He means check your cooling system because white smoke is usually indicative of coolant being burned in the motor. You might have a slight hg leak--I am not saying you have a "blown headgasket"--but it might be weeping a little coolant into the combustion chamber. Take off your rad. cap and see if there are little drops of oil floating in the coolant. You can also remove the valve cover to check if the oil looks like a chocolate "milkshake"--usually means hg problems...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d16dcoe45 »</TD></TR><TR><TD CLASS="quote">He means check your cooling system because white smoke is usually indicative of coolant being burned in the motor. You might have a slight hg leak--I am not saying you have a "blown headgasket"--but it might be weeping a little coolant into the combustion chamber. Take off your rad. cap and see if there are little drops of oil floating in the coolant. You can also remove the valve cover to check if the oil looks like a chocolate "milkshake"--usually means hg problems...</TD></TR></TABLE>
well said bro
well said bro
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZacCarter »</TD></TR><TR><TD CLASS="quote">no need to go to redline, your car quits making power before then.</TD></TR></TABLE>
The dyno numbers disagree with your statement. The ideal shift point for a stock GSR is just before the rev limiter. The engine has more power at redline than at 6000 RPM after shifting.
http://www.aempower.com/pdf/dy...s.pdf
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator »</TD></TR><TR><TD CLASS="quote">The dyno numbers disagree with your statement. The ideal shift point for a stock GSR is just before the rev limiter. The engine has more power at redline than at 6000 RPM after shifting.</TD></TR></TABLE>
I think not the power curve drops after 7500 rpm, why put increased stress on your motor?
I think not the power curve drops after 7500 rpm, why put increased stress on your motor?</TD></TR></TABLE>
Normally you don't need to shift at redline. But if you are racing, it is optimal to shift at redline in a GSR. As I said before, the motor makes more power at redline than at 6000 RPM. The dyno chart doesn't lie.
CityHunt3r
Sep 30, 2003 05:07 AM
