"Clunking" noise when clutch is engaged/disengaged ?
Old Feb 24, 2002 | 03:03 PM
VTi NA's Avatar
Default "Clunking" noise when clutch is engaged/disengaged ?
A minor annoyance I'm facing here. There is a distint "clunk" when the clutch is engaged in every gear. Its somewhat loud in the lower gears, but faint when the car is moving and I'm in a higher gear (3rd onwards, of course, the exhaust sorta drowns out any noise anyways). I also get the same noise when disengaging the clutch (again, more distint in lower gears). Anyone care to guess whats causing this? Recent maintenance includes replaced axles 2000 miles ago. Other than that, the car runs fine. Suggestions appreciated!
Old Feb 24, 2002 | 03:36 PM
91DA9's Avatar
Default Re: "Clunking" noise when clutch is engaged/disengaged ? (STi -RA)
it could be the differential gears. My car does the same thing.
Old Feb 24, 2002 | 11:21 PM
VTi NA's Avatar
Default Re: "Clunking" noise when clutch is engaged/disengaged ? (94IntegraGSR-OVR)
OVR, are you planning to get it fixed or no? Any estimate on how much?
Anyone else?
Old Feb 26, 2002 | 07:08 PM
GTM's Avatar
GTM
The sound you're describing is common when motor mounts or torque mounts go bad.
Start by checking 3 of the 5 mounts in your car. Don't worry about the 2 that you can see from the top of the motor.
1. Front Left torque mount (also A/C bracket) going to underside of frame
2. Front Right torque mount from Trans going to underside of frame
3. Rear motor/trans mount
Old Feb 26, 2002 | 09:40 PM
wizzards581's Avatar
Default Re: "Clunking" noise when clutch is engaged/disengaged ? (GTM)
i was told that its the motor mounts... the motor mounts doesnt seem to be cracked...? or anything...
SubwayH23
Aug 9, 2018 03:11 PM
Old_Liver
Honda Fit
Jun 21, 2017 01:02 AM
98BlackTeg
Aug 24, 2005 09:14 AM
MoogieBoogie
Sep 16, 2004 10:04 PM
geminis2k
Jan 28, 2003 01:27 PM
