whine at higher rpms
Old Aug 23, 2005 | 10:50 AM
eg6nes's Avatar
Default whine at higher rpms
i get a little whine from my d15b7 at the higher rpms is this normal or not?
Old Aug 23, 2005 | 10:54 AM
nighttrain33's Avatar
Default Re: whine at higher rpms (primed)
If it is turbo then yes .
For real though, do you have anything done to it?
-Shane
Old Aug 23, 2005 | 11:03 AM
FalkenSiR's Avatar
Default Re: whine at higher rpms (nighttrain33)
Supercharger?
check your belts.
Old Aug 23, 2005 | 11:36 AM
92eg6lsvtec's Avatar
Default Re: whine at higher rpms (fast88std)
timing belt to tight?? happened to me
Old Aug 23, 2005 | 02:08 PM
eg6nes's Avatar
the motor is NA. What could happen if the timeing belt is to tight?
Old Aug 23, 2005 | 02:45 PM
ThatsMyEG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by primed &raquo;</TD></TR><TR><TD CLASS="quote">the motor is NA. What could happen if the timeing belt is to tight?</TD></TR></TABLE>
it could, 1. break 2. make alot of noise 3. throw your timing off, if i were you id start there
Old Aug 23, 2005 | 04:06 PM
Default Re: whine at higher rpms (ThatsMyEG)
yea, u dont want it breaking or ull be rebuilding the head just loosen the tensioner a lil bit, then tighten it back up and ull be good to go!
95turbotypeR
10
Jan 1, 2011 07:45 PM
DJaeMac
Honda Civic (2001 - 2005)
Oct 10, 2007 06:42 AM
migs
Jan 31, 2006 12:34 AM
Sam268
Sep 20, 2003 10:00 PM
civickidd99
Jul 7, 2003 11:12 AM
