edelbrock manifold problem ?
Old Aug 23, 2005 | 09:25 AM
TyeJ23's Avatar
Default edelbrock manifold problem ?
i am installing my edelbrock manifold on my 98 gsr and i have a few questoins.....
When i use my stock injectors and fuel rail, there is almost a 5/16 gap to where the fuel rail mounts... is this normal, do i need to make spacers?
Send a pic if anyone has one with the stock fuel rail
Old Aug 23, 2005 | 10:49 AM
TurboCoop's Avatar
Default Re: edelbrock manifold problem ? (TyeJ23)
This is a pic I took of the throttle cable holder, but you can kind of see where the spacer is where it mounts up(on the bottom between the injectors). I just used the stock spacers(painted silver), but I had to go to the harware store and get longer bolts. And for the throttle cable holder, I used the stock one off of an LS IM and bent it a little and it works perfect, but I think I heard you can use one from a type-r IM and it works even better??
Old Sep 2, 2005 | 07:38 AM
Beyond_Redline's Avatar
Did you find the spacers you needed?
We just found a similiar situation on a 2000 GSR. We are considering adding spacers and longer bolts (or studs) to the kits from now on. Are the 1998 and later fuel rails different from earlier ones?
thanks
Old Sep 2, 2005 | 01:24 PM
TyeJ23's Avatar
Default Re: edelbrock manifold problem ? (Beyond_Redline)
i just machined spacers out of 3/4 alum round stock... i used the original studs from the stock b18c IM
jon570
Mar 7, 2019 07:01 AM
type Gendy
Nov 13, 2007 05:41 PM
adictionbass
Aug 6, 2005 05:39 PM
swaytec360
Mar 1, 2005 07:33 PM
zCivic
Feb 23, 2004 04:11 PM
