First Time Newbie Question:
Old Aug 23, 2005 | 04:26 AM
oldberkeley's Avatar
Default First Time Newbie Question:
I want to change the fuel filter on a 1991 Civic. Do the in and out fuel line fittings actually "unbolt" from the filter? Thats how it looks. Can anyone walk me through the process. Thanks!
Old Aug 23, 2005 | 04:37 AM
sam385's Avatar
Default Re: First Time Newbie Question: (oldberkeley)
1. put a rag under the filter to catch the drips
2. relieve fuel pressure--don't get sprayed in the eye w/ gas --be careful--
remove gas cap; disconnect neg batt terminal (to avoid possible sparks); use
6mm wrench to turn service bolt 1 turn or so while holding the banjo bolt w/ another wrench; use rags to shield service bolt as this is where the gas will spray out
3. remove 12mm banjo bolt and the fuel feed pipe
4. remove strap and filter
5. use new washers when replacing
hope this helps
solfly's Avatar
its easy, just releave the pressure beforehand
pull the fuel pump fuse and start the car then let it die
Old Aug 23, 2005 | 04:44 AM
65stang90crx's Avatar
First you do unbolt the lines in and out careful to relieve the fuel pressure, I believe that you have to unclip the holder for the fuel filter as well. The new filter will come with new bronze washer things, make sure that you do use them. bolt the lines back onto the new filter and presto better fuel flow in 20 mins! (Its been awhile so if I forgot a step thats why) Hope this helps
Old Aug 23, 2005 | 04:55 AM
CRX Toad's Avatar
Default Re: First Time Newbie Question: (65stang90crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 65stang90crx &raquo;</TD></TR><TR><TD CLASS="quote">First you do unbolt the lines in and out careful to relieve the fuel pressure, I believe that you have to unclip the holder for the fuel filter as well. The new filter will come with new bronze washer things, make sure that you do use them. bolt the lines back onto the new filter and presto better fuel flow in 20 mins! (Its been awhile so if I forgot a step thats why) Hope this helps</TD></TR></TABLE>
Old Aug 23, 2005 | 05:22 AM
Thanks for the quick response.
Another question: I'd like to change the manual transmission oil and the differential gear oil.
1. Can someone walk me through the process for both?
2. What oils should I use? (Can they both be the same oil?)
Thanks again!
Old Aug 23, 2005 | 05:27 AM
Do you have a service manual?? They can be VERY VERY helpful. Autozone for like 14 bucks well worth the time for stuff like this.
Old Aug 23, 2005 | 05:54 AM
CRX Toad's Avatar
I would listen to him and get manual ^
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oldberkeley &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for the quick response.
Thanks again!</TD></TR></TABLE>
Go to Honda and get the manual transmission fluid. The differential is in the transmission so they take the same oil and it all goes in the same place.
Old Aug 23, 2005 | 07:14 AM
Kidnkorner's Avatar
Default Re: First Time Newbie Question: (sam385)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sam385 &raquo;</TD></TR><TR><TD CLASS="quote">2. relieve fuel pressure--don't get sprayed in the eye w/ gas --be careful--
6mm wrench to turn service bolt 1 turn or so while holding the banjo bolt w/ another wrench; use rags to shield service bolt as this is where the gas will spray out</TD></TR></TABLE>
could he just pull the fuse for the fuel pump while the car is running to relieve pressure? Is there a fuse for the fuel pump? I did this on a 96 S10.
magic hat #9
Jan 9, 2009 07:23 AM
dirty nails
Nov 4, 2007 03:20 AM
mrredrocker
16
Oct 6, 2005 10:45 PM
LiZaRDz CiViC Si
Mar 19, 2003 09:17 AM
samdawgsol
May 13, 2002 09:40 AM
