ls block, gsr rotating assem. compression?
Old Aug 23, 2005 | 02:10 AM
steelies's Avatar
Default ls block, gsr rotating assem. compression?
Here's the deal, I had an ls setup, stock. Went boost, decided to just go ahead and build the bottom end. I stuck w/ the ls block, but obviously went w/ the gsr internals.
This leads to my question, what kind of compression "should" I be seeing w/ an ls block, w/ gsr crank, rods and wiseco 9.1.1 compression pistons w/ teh ls head?
If anyone has any insight on this, I'd appreciate the info.
Old Aug 23, 2005 | 06:06 AM
PURPLETERROR aka BIGMATT's Avatar
Default Re: ls block, gsr rotating assem. compression? (steelies)
Uh, 9.1-1
Old Aug 23, 2005 | 06:21 AM
klungemonger's Avatar
Actually, if the pistons are 9.1 c/r for GSR then you'll actually end up with lower than that since the LS chambers are larger. Putting the GSR crank/rods should have no effect on compression, it's piston choice that makes the difference.
CharliesEG
Oct 27, 2016 06:19 PM
young geezer
Oct 12, 2010 08:20 PM
junfanclaw
May 1, 2005 04:45 PM
BlkslowCRX
12
Feb 9, 2005 10:18 PM
NightmareApex
22
Dec 18, 2004 10:53 PM
