LSVTEC motor, worth throwing in GSR cams?
Old Aug 22, 2005 | 11:55 PM
Sketch_hs's Avatar
Default LSVTEC motor, worth throwing in GSR cams?
Yeah i've got b18b block and b16a head so
would it be worth it to go to gsr cams? I'm using a gt28rs @ 10lbs after i get it tuned. I thought the cams were almost the exact same but i hear the gsr cams can be better.
I'm looking for the best lowend + midrange this is a daily driver
Old Aug 23, 2005 | 12:43 AM
J-Brooks's Avatar
Default Re: LSVTEC motor, worth throwing in GSR cams? (Sketch_hs)
gsr would be better than b16 cams... there is some dynos floating around with substantial gains... and even more gains with some ITR cams and some cam gears!
Old Aug 23, 2005 | 06:00 AM
213374U's Avatar
0x5359-0055
Community Builder
Default Re: LSVTEC motor, worth throwing in GSR cams? (J-Brooks)
http://www.webcamshafts.com will custom grind cams to your particular setup
Old Aug 23, 2005 | 09:35 AM
vaporboy12's Avatar
Default Re: LSVTEC motor, worth throwing in GSR cams? (Vt4cPwn35)
he wasnt asking for custom cams.
but yes you will pick up gains from a b16 cam to a gsr cam
Old Aug 23, 2005 | 09:44 AM
noboostedEGo's Avatar
http://forums.evans-tuning.com...=2341
Hope that helps, midrange gains are huge, almost 50 whp/tq!
jksmith
Nov 3, 2008 05:52 PM
sonny0330
Jul 18, 2007 01:24 PM
91b16civic
May 13, 2003 04:26 AM
sean
Aug 16, 2002 01:32 PM
PYITR821
Jun 9, 2002 01:07 PM
