Suspension & Brakes Theory, alignment, spring rates....
GC and Koni
Old Aug 22, 2005 | 11:22 PM
Dirk-EG's Avatar
Default GC and Koni
I've had it with my Omnipower Streets.. They dont do what I want them to do and what I expect from handling, so now I have to get another set..
I now want GC's on Koni's... But I kinda liked the 10kg/mm 8kg/mm springs, how much is that in LBS?
And I want the koni's that are adjustable from the top, Is it wise to have them revalved to my needs, or will OTS Koni's work for me?
Old Aug 23, 2005 | 12:08 AM
Johnny Mac's Avatar
Default Re: GC and Koni (Dirk-EG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dirk-EG &raquo;</TD></TR><TR><TD CLASS="quote">I've had it with my Omnipower Streets.. They dont do what I want them to do and what I expect from handling, so now I have to get another set..
And I want the koni's that are adjustable from the top, Is it wise to have them revalved to my needs, or will OTS Koni's work for me?</TD></TR></TABLE>
The conversion for kg/mm is 55.088 lbs/in. Therefore, 10 kg/mm = 551 lbs/in and 8 kg/mm = 447 lbs/in.
OTS Konis should be fine for street and auto-x while you're learning. When you have more experience or will race on the track, you'll probably want to get them re-valved.
Old Aug 23, 2005 | 12:58 AM
Dirk-EG's Avatar
Default Re: GC and Koni (Johnny Mac)
Okay, thanks
Old Aug 23, 2005 | 02:37 AM
ingrate's Avatar
25 Year Member
IMO 550f/447r may be a little stiff for OTS konis. it'd probably be better to buy a used/blown set for cheap and then send it back for revalving.
Old Aug 23, 2005 | 09:33 AM
Dirk-EG's Avatar
Default Re: GC and Koni (ingrate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ingrate &raquo;</TD></TR><TR><TD CLASS="quote">IMO 550f/447r may be a little stiff for OTS konis. it'd probably be better to buy a used/blown set for cheap and then send it back for revalving.</TD></TR></TABLE>
Then it must also be possible for Koni to custom revalve me a set..
Old Aug 23, 2005 | 10:09 AM
slammed_93_hatch's Avatar
not really 550 is approaching high for OTS but this is on an EG so its not some 2600 lbs car.
you would be fine with those rates on OTS shocks
Old Aug 24, 2005 | 12:12 AM
Dirk-EG's Avatar
Would it be worth the money to also get those GC tophats.. I'm lowering about 2,5"
Old Aug 24, 2005 | 12:28 AM
Default Re: (Dirk-EG)
it will allow you to reach your desired ride height, while maintaining more travel out of the damper.
In my opinion thats always a good thing, but i wouldn't say its needed for your setup
Old Aug 24, 2005 | 07:02 AM
vtecvoodoo's Avatar
Future Texas Boy
Community Builder
You`ll find that the most common rates are 400/450, 400/500 and 450/500.
Old Aug 24, 2005 | 08:29 AM
chrisw85's Avatar
vtecvoodoo, you list those as the most common rates, however, i have been recently reading that you want the higher rates in the front. I suppse getting the same length springs front and rear would allow easy manipulation to test out the difference.
I was personally thinking of going with 450F/375R.
Old Aug 24, 2005 | 08:39 AM
vtecvoodoo's Avatar
Future Texas Boy
Community Builder
Default Re: (chrisw85)
Sorry, "400/450" doesn`t mean 400 front and 450 rear. It`s just the way I keyed it in. You`ll get many different opinion when it comes to this subject. I just run the same length spring so I can try them both ways.
Old Aug 24, 2005 | 11:46 AM
808_si's Avatar
i am going to run the same length springs as well, noob question, what is the preferred length, i have a 2000 civic si.
Old Aug 25, 2005 | 10:47 AM
macDelli's Avatar
Default Re: (808_si)
spend a grand on custom rated gc's/koni/gc top hats
Old Aug 25, 2005 | 11:18 AM
bad-monkey's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 808_si &raquo;</TD></TR><TR><TD CLASS="quote">i am going to run the same length springs as well, noob question, what is the preferred length, i have a 2000 civic si.</TD></TR></TABLE>
7" is a good length.
Old Aug 25, 2005 | 11:41 AM
808_si's Avatar
thanks
2ToneEM1
20
Nov 26, 2007 03:08 PM
Jxi8s2k
Suspension & Brakes
15
Apr 26, 2006 07:10 AM
alwaysoverkill
Suspension & Brakes
Oct 31, 2005 07:22 PM
japhonda
Suspension & Brakes
11
Aug 26, 2005 10:43 AM
Preludster
Nov 17, 2003 04:19 AM
