Before I order Koni yellows
Before I spend $500 on these, got a question.
where it says they have adjustable spring seats for adjustable ride heights, will I be able to use this to lower my car more without having to cut my springs or get a different set?
The springs are eibach sportlines
Re: (Neebs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Neebs »</TD></TR><TR><TD CLASS="quote">Ones for stock height and the other is for lowering about an inch more.</TD></TR></TABLE>
Perfect should be exactly the drop im trying to achieve.
Re: Before I order Koni yellows (2ToneEM1)
i dont think you can run just a spring with konis... you will need the coil sleeve perch type for them to fit.
Re: (Neebs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Neebs »</TD></TR><TR><TD CLASS="quote">Did you buy the Koni's made for the springs?</TD></TR></TABLE>
Havent ordered them yet, just wanted to make sure I could use them to lower the car more first.
Should be these correct?
http://www.tirerack.com/suspen...ode=S
Re: (2ToneEM1)
hey i dont think you can just put springs on them and be good... there is something else you need to do. do u have aim?? if you ill get u the sn to a koni specialist who can tell you what works and answer all your questions.
Hmm, if the konis wont work with just springs is there another setup you can reccommend that will lower my car about another inch? I think the sportlines are around a 1.6 inch drop, so im wanting around 2.5-3 inch
Edit: I have around $600 to spend
Re: (thw_goalie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thw_goalie »</TD></TR><TR><TD CLASS="quote">The Koni's work exactly the same way your OEM shocks work. It's a direct replacement, so yes they will work with just springs.</TD></TR></TABLE>
Ok, thought they would just wanted to make sure.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2ToneEM1 »</TD></TR><TR><TD CLASS="quote">
The springs are eibach sportlines</TD></TR></TABLE>
The lower spring perches are not to be used with anything other than OEM springs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2ToneEM1 »</TD></TR><TR><TD CLASS="quote"> how much of a drop is there?</TD></TR></TABLE>
I forget the exact number, but it's something like 1/2 to 1". Again, it's for OEM springs only.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93egSLEEPER »</TD></TR><TR><TD CLASS="quote">i dont think you can run just a spring with konis... you will need the coil sleeve perch type for them to fit. </TD></TR></TABLE>
Yes, you can. It comes with stock spring perches (which will also work with aftermarket springs). GC coilovers come with their own perch that works with the C-clip that the stock perches mount to.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tarmac Junkie »</TD></TR><TR><TD CLASS="quote">The adjustable sleeves are for ride height, and so you can corner weight it.</TD></TR></TABLE>
Sleeves on the coilovers. Not the adjustable mounts on the Konis.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2ToneEM1 »</TD></TR><TR><TD CLASS="quote">Hmm, if the konis wont work with just springs is there another setup you can reccommend that will lower my car about another inch?
They will work. But just by buying the shocks, you won't be able to lower the car with springs. You will need a coilover setup.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2ToneEM1 »</TD></TR><TR><TD CLASS="quote">I think the sportlines are around a 1.6 inch drop, so im wanting around 2.5-3 inch
To lower that much you will need GC coilovers with a very high springrate. THat's going to lead to a pretty uncomfortable ride. Otherwise you'll be bottoming out the shocks.
Big Dog
04-16-2009 07:21 PM
SpecialEdScott
03-01-2003 01:12 PM
