Honda civic lx 93 is overheating now dont want to trun on help me
[B]Honda civic lx 1.5 automatic
when step on the gas, to be out. the car overheats
when I step on the gas slowly the car don't overheats. but am going mad slow. so the car can get up to speed whit out overheating.
I have to keep the rpm at 3 and not press the gas to much, so it wont overheat.
I took out the thermostat thinking that was the problem, but even with out the thermostat install it still over heating what does this mean.?
today it overheat to much now I had white smoke coming out the hood.
when I turn my car on it turn right back off
now if I hold the key to on position the car stays on but when I take my hands of the key it turns back off.
I ran a wire from the battery to (ACG) 15 fuse inside the car and then I turn the key to on.
the car turns on but now I take the key off the ignition and the car stay on until I disconnect the wire that I put from the battery to (ACG) fuse.
thinking it was the distributor cap I take it off to check it out.
cant get to the screw the holds the Rotor
so I turn on the car so it can turn the Rotor and I can get to the screw.
it did, I get the screw out I don't know what am looking for just waiting for something to pop out and say fix me nothing seem to be wrong whit the distributor cap so I put everything back on the way it was.
now I forgot how the spark plug goes connected to the cap.
I put them on the way I think it goes. I go back into my car turn the car on
the whole car shakes and turn off .
I go back and change the spark plug the way I think they go and fire it up again. same thing happens. I keep going back changing the spark plug location about 6 more times until I said I give up.
now the car went from firing on and staying on by getting power from the battery to (ACG) fuse
to
shaking the whole car and turning right back off.
Help Help help this car making me crazy.
Modified by luckygispol1 at 12:58 AM 8/23/2005
Modified by luckygispol1 at 12:59 AM 8/23/2005
to
wtf.... dude learn how to type i got dizzy but i read it... if its overheating you probably blew a head gasket.. white smoke is not good... or a radiator hose... i dont know how to help you cuz i cant read ur damn paragraph...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93egsedan »</TD></TR><TR><TD CLASS="quote">wtf, go to school, learn to write, retype the paragragh</TD></TR></TABLE>
I second that
I second that
For the plugs the order is as follows:
Standing at the front of the car, looking at the dizzy, the first plug is #1, top is #2, bottom is #3, and back is #4
Check all of your fuses after you fix your plugs and see if the car turns over.
thanks nota-eg for your info I will check it on Friday. for the rest. sorry, I didn't go to school with ya dicks ya to smart for me. didn't know I was giving in a professional essay. whit paragraphs that ya like.
nisbo
May 26, 2009 01:11 PM
handa
Jan 21, 2004 02:03 PM
