EG civic front speakers
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AZNracerx1989 »</TD></TR><TR><TD CLASS="quote">The size for the front EG civic speaker is 6 1/2... does this mean that all 6 1/2's will fit? or is there a height limit?</TD></TR></TABLE>you mean depth?
yeah there is a depth limit...but you can unscrew that black basket and cut out the back so the speakers' magnent can fit in or you can just take a saw or dremel and cut it while its still in the door.
that fix wont always work
i got 6.5 infinity references, the woofer was sitting againts the door panel, unless you want to cut ur door panel, which will make the grill not fit any more, i suggest you research for speakers that fit the front.
so, infinity references = no for front, unless you can make ur own mounting bracket, or buy one to replace that POS plastic one.
i found the kenwoods tend to fit perfectly, but they arent as good as other speakers
Check crutchfield.com they will have and know everying that fits your car. Here ya go... http://www.crutchfieldadvisor.....html
IF you're having trouble with depth even after cutting the basket...make a small MDF baffle.
Basically its a peice of wood used as a "riser" around the mounting ring on the speaker...so in the end, the speaker is mounted say a half an inch further out than the original mouting place..
The grille MAY not fit back on..but ****, the speakers in there.
No, you do not need a special 3 way deck hahaha.
Do you know why you want 3 ways? If you plan on using your deck to power these, as opposed to an external amp, you may be underpowering them.
Alot of 3way speakers have a built in crossover, and sometimes have to be wired differently.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R81DC4LS »</TD></TR><TR><TD CLASS="quote">IF you're having trouble with depth even after cutting the basket...make a small MDF baffle.
The grille MAY not fit back on..but ****, the speakers in there. </TD></TR></TABLE>
i dont see how that can work, as i said before my infinity references without a "riser" were sitting againts the door panel, which would muffel the sound and destroy the speaker.
fryman
Feb 5, 2015 09:21 AM
VOLTRONRacing
12
Oct 1, 2005 02:39 PM
