Need Help!! OBD1 GSR Motor Into OBD2 DX DELSOL ?
Old Aug 22, 2005 | 07:41 PM
integlspwr2k's Avatar
Default Need Help!! OBD1 GSR Motor Into OBD2 DX DELSOL ?
Does the obd1 gsr engine side wiring harness match the obd2 delsol wiring.....
The pinouts seems to be in different locations...
Please only reply or respond if you have done the swap personally!!
Thanks!
-integlspwr-
Old Aug 23, 2005 | 02:24 AM
Default Re: Need Help!! OBD1 GSR Motor Into OBD2 DX DELSOL ? (integlspwr2k)
Old Aug 23, 2005 | 02:29 AM
JDMlyfestyle's Avatar
well your gonna have trouble anyways you still gotta wiring up the secondary runners or IAB. Your best bet would be to get a GSR OBDII harness and OBDII ECU
Old Aug 23, 2005 | 03:00 AM
Default Re: (JDMlyfestyle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle &raquo;</TD></TR><TR><TD CLASS="quote">well your gonna have trouble anyways you still gotta wiring up the secondary runners or IAB. Your best bet would be to get a GSR OBDII harness and OBDII ECU</TD></TR></TABLE>
well its not an option at the moment.... thanks for the reply though.
Old Aug 23, 2005 | 01:31 PM
no body this this swap before?
Old Aug 24, 2005 | 04:37 PM
does even anyone have a 96 delsol with a motorswap?
Old Aug 25, 2005 | 02:01 PM
Old Aug 25, 2005 | 02:04 PM
Luserkid's Avatar
Although thats a good idea, i would rather just get a jumper harness and put a OBD1 P72. Your still going to need to wire up everything but youll be at OBD1. and its easier. The way that was said it would involve getting OBD2 injectors, alternator and distributor.
Old Jul 22, 2006 | 12:04 PM
DelsolioGSR1996's Avatar
Default Re: (Luserkid)
Ya Im in the same boat with my 1996 del sol and 1994 GSR swap. I already have the obd2a~obd1 conversion harness for ecu. But I need the convertor for the distributor wiring??? obd2a dizzy to obd1??? there is a convertor I need for this right? or buy a obd2 dizzy for the gsr?? but that would mean obd2 injectors too wouldnt it?
HarosGSRek
Jan 27, 2011 10:20 AM
JustAskMe
Aug 19, 2010 10:47 AM
zsoccerdude17
Mar 10, 2010 06:42 PM
Cain Marko
Jul 7, 2004 02:40 PM
