throttle sticking!!
Old Aug 22, 2005 | 06:28 PM
honda011's Avatar
Default throttle sticking!!
when i drive my throttle sticks, sum times bad to but when it sticks it doesn't stay at that rpm it just drops, so what could be the cause of my throttle sticking??
Old Aug 22, 2005 | 06:50 PM
LSDC-4's Avatar
Default Re: throttle sticking!! (honda011)
does the pedal stay stuck too? or does it come back up when u let your foot off of it? could b that your pedal gets stuck to your carpets or mats. its happened to me
Old Aug 22, 2005 | 07:05 PM
honda011's Avatar
Default Re: throttle sticking!! (LSDC-4)
no its not from the carpets or mats. it stays till i like kick it down.. i just but new carpet down so its not that.. it did it when it was in my integra but now in my hatch is worse..
Old Aug 22, 2005 | 07:33 PM
Racermech's Avatar
Does the throllte cable have any bad bends or kinks in the cable???
If you just open a close the TB using the "pulley" will it stick. If so it sound like the spring is dirty and needs a good clean and lube.
I would try a little WD-40 to clean and lube the spring thing.
Old Aug 22, 2005 | 08:09 PM
honda011's Avatar
Default Re: throttle sticking!! (Racermech)
i tried wd-40 i don't drive the car much cuz its not insured yet jus want these little problems fixed 1st.. but one time my throttle was actually stuck coludn't push the peddle down so the bolt thats by the cable i loosend it a lil bit and it was fine... but evey now again this problem happends. sorry i suck at explaining things..
The Seller
Oct 15, 2013 07:56 PM
raidacaipo
Oct 12, 2008 06:42 PM
theresyourproblem
Oct 4, 2007 09:28 AM
mkazm83
Jul 5, 2007 08:47 PM
andlude
Nov 9, 2005 08:35 PM
