problem with swap
I requested a short story for a title.
i did a search on this but i couldnt come up with anything. OK my friend is swaping a b18a1 from a 91 integra into his 95 civic hatch. Everything was done the right way and everything was ordered from hasport but he has run into a problem with the harness. Now i heard hasport sells kits that hook up to the stock harness and are made to plug right in to the new motor but i have had no luck finding these. He even took it to a shop and they could not diagnose the problem. Has anyone done this same swap???????? If so PLEASE help out my friend, he has been dickin around with this for like a couple months and is gettin tired of it so i figured i ask on here. THANKS FOR THE HELP
Is the motor wiring harness not clipping up? If so get OBD 1 Dizzy,ecu, and header w/ O2 Sensor. Convert motor from OBD 0 to OBD 1 just like your car already is.
no its not it kinda came with a half *** harness. like some things hook up and some doenst i dont kno what the hell is goin on. Can you buy those somewhere or does he just have to get lucky and find one from someone on here. Will the whole dash have to be ripped apart and all that??
If he is not running LS vtec and his car was non tech his factory motor harness should fit the B18 motor ( mine did, but I used a the B18B swap rather than B18A much different). If he is running LSvtec and the car was'nt vtec he will have to do some wiring.. But anyway the ecu is on the passenger side kick panel easy to get to, all can be found brand new, used, here, performance,shops, or junkyards.
no the engine is not vtec and the motor that was in it was not vtec either. He did buy one of them chipped ECU's that was made for that engine and it plugged right in, so i dont kno what the hell is goin on. but thanks for the help
b18a1 from a 91 integra to 95 civic hatch, both non vtec, what needs to be done as far a wiring, I searched a couldnt find anything helpful??? please help me out
What exactly is not plugging up? From what i am understanding you are running a obd0 motor into a obd1 car. First off, did you convert the motor to obd1 or the cars harness to obd0? also what plugs are not plugging in or do not have a place toplug into. What ecu are you running?
well its my friends car but from what i uderstand, he is runnin and OBD0 motor to a OBD1.I kno that wont work so what needs to be done to fix it The ECU is a chipped ECU made for the B18a1 and it plugged rigth into the civic harness. also there r some fluid lines running out of the tranny, do those get plugged or get ran somewhere? im not sure what doesnt hook up but enough of it does to make the car turn over. Sorry the sounds like a big mess, but its been awile since ive looked under the hood.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stocker2shocker91 »</TD></TR><TR><TD CLASS="quote">well its my friends car but from what i uderstand, he is runnin and OBD0 motor to a OBD1.I kno that wont work so what needs to be done to fix it The ECU is a chipped ECU made for the B18a1 and it plugged rigth into the civic harness. also there r some fluid lines running out of the tranny, do those get plugged or get ran somewhere? im not sure what doesnt hook up but enough of it does to make the car turn over. Sorry the sounds like a big mess, but its been awile since ive looked under the hood.</TD></TR></TABLE>
Well if the ecu plugged right in then it is still obd1. inside the car and the ecu is also a obd1. As far as the engine harness side was anything changed? Is the tranny auto or 5 speed? if its auto the it most likely the tranny cooler lines. if its 5 speed then what tranny is it? Post some pics up of the problem will help out alot. if you can.
no nothing in the harness was changed it is a 5speed, and im not sure of the tranny type but i kno it is the stock one that comes with the B18a1, i can try and get some pics but the car is in a different town right now so it might take awile but ill try. Could those still be cooling lines. I have a 91 integra and we have been kinda lookin off that and those lines seem to run from the tranny like underneath the car or into the fire wall? its back there
he had his car on car domain. here is the link i dunno if these will help the might not be close enough but here ya go http://www.cardomain.com/ride/854730
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stocker2shocker91 »</TD></TR><TR><TD CLASS="quote">no nothing in the harness was changed it is a 5speed, and im not sure of the tranny type but i kno it is the stock one that comes with the B18a1, i can try and get some pics but the car is in a different town right now so it might take awile but ill try. Could those still be cooling lines. I have a 91 integra and we have been kinda lookin off that and those lines seem to run from the tranny like underneath the car or into the fire wall? its back there</TD></TR></TABLE>
the tranny is still cable. you have to convert to hydro. also you have to change a couple things to obd1, as mentioned above. What harness are you running? the one from the Eg, or from the motor.
https://honda-tech.com/zerothread?id=728372
take a look at that for the wireing for the injectors.
He already did they tranny conversion from hasport. Well he is runnin the stock harness from the civic,all the wiring in the dash and stuff is fromt the civic, the only thing from the integra harness is what is connected to the engine, . some of the connectors fit and some dont. wow this is makin me sound like an idiot
No im just trying to get a better understanding. do a search for obd1 to obd0 conversion, and go from there. there are like 600 results. But as usaul only like 10 will be helpful. I take a look at some for you.
well i am tired as hell im gonna head to bed i will check that out tommaro for sure and ill see what you came up with thanks for all the help, peace out
