Has anyone ever installed an aftermarket muffler and it screw up your idle ???
Old Aug 22, 2005 | 04:32 PM
ApolloSpeed's Avatar
Default Has anyone ever installed an aftermarket muffler and it screw up your idle ???
I just installed an N1 muffler on my Del Sol B16 which is all stock except for CAI and a test pipe.......
and now my idle pulses from 800 rpm to 1400 rpm consistently !
whats up with that ?
Old Aug 23, 2005 | 10:05 AM
Default Re: Has anyone ever installed an aftermarket muffler and it screw up your idle ??? (ApolloSpeed)
anyone ????
I unpluged my battery for about5 minutes......still same bouncy idle....
Old Aug 23, 2005 | 01:46 PM
anybody out there?
Old Aug 23, 2005 | 01:48 PM
92HatchB16's Avatar
Are you getting any Check Engine Lights??
Old Aug 23, 2005 | 01:53 PM
Default Re: Has anyone ever installed an aftermarket muffler and it screw up your idle ??? (92HatchB16)
no SES....... but, Idle is jumpy from 800-1400......only when the engine is up to temp!
Old Aug 23, 2005 | 01:54 PM
SirRevvs's Avatar
sounds like a vaccuum leak in the manifold. You sure you didn't unplug any hoses?
And no, installing a muffler will not cause irratic idle.
Old Aug 23, 2005 | 01:57 PM
Default Re: Has anyone ever installed an aftermarket muffler and it screw up your idle ??? (SirRevvs)
maybe I do have a leak somewhere........any "quick" way to check ?
Or just go one by one ?
Old Aug 23, 2005 | 03:55 PM
eg6_rick's Avatar
heres what i did to check for vac leaks:
1. remove your intake.
2. have a friend start the car.
3. cup the palm of your left hand onto the intake mani.
4. if car erratically idles down and not idling like you said and you can hear a slight whistling or sucking/pshhing noise, there might be a leak somewhere. otherwise the engine would just die then theres no leak.
I might be wrong on so many levels, but this method worked for me.
hope this helps you. LMK if you need more advice.
~Rick
Old Aug 23, 2005 | 04:01 PM
SirRevvs's Avatar
Default Re: Has anyone ever installed an aftermarket muffler and it screw up your idle ??? (eg6_rick)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6_rick &raquo;</TD></TR><TR><TD CLASS="quote">heres what i did to check for vac leaks:
~Rick
Good advise, I'll have to remeber that
Old Aug 23, 2005 | 04:13 PM
92ehatch's Avatar
there are 2 holes in the IM, if you cover the top one with ur finger it will do the same
jimmer21
Honda CR-V & Element
Mar 1, 2019 11:02 AM
VTECwalka
Nov 4, 2012 06:58 PM
mortificationrock
11
Jan 1, 2010 03:01 PM
the.hamburglar
Apr 17, 2007 05:13 PM
Civic Racer X 7
Jul 23, 2003 07:19 AM
