Anything Else I Should While I'm Doing This?
Old Aug 22, 2005 | 02:31 PM
TegoDC5's Avatar
Default Anything Else I Should While I'm Doing This?
Hey, I'm doing a tune-up on my car this week hopefully, so far I'm doing the following:
- sparkplugs
- air filter
- fuel filter
- distrubitor cap
- oil & oil filter
Anything else I should do, while I'm doing it?
Old Aug 22, 2005 | 02:46 PM
Bond's Avatar
Default Re: Anything Else I Should While I'm Doing This? (Tego)
Check all fluids and maybe change your sparkplug wires if there due for a new set.
Old Aug 22, 2005 | 03:12 PM
mericbe's Avatar
get a rotary butoon too if your gonna rplace the cap. There are like 7 bucks for an LS like AutoZone or somewhere
Old Aug 22, 2005 | 03:21 PM
TegoDC5's Avatar
Default Re: Anything Else I Should While I'm Doing This? (mericbe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mericbe &raquo;</TD></TR><TR><TD CLASS="quote">get a rotary butoon too if your gonna rplace the cap. There are like 7 bucks for an LS like AutoZone or somewhere</TD></TR></TABLE>
What does this do? Sorry for being dumb.
Old Aug 22, 2005 | 03:26 PM
mericbe's Avatar
Ok once u take the dizzy cap off there is a disc called the rotary button can be taken off w/ a phillips head. I transfers the spark from dizzy to cap basically to wire and so on.
Old Aug 23, 2005 | 06:53 AM
Bond's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mericbe &raquo;</TD></TR><TR><TD CLASS="quote">Ok once u take the dizzy cap off there is a disc called the rotary button can be taken off w/ a phillips head. I transfers the spark from dizzy to cap basically to wire and so on.</TD></TR></TABLE>
^^^Everyone just calls it a rotor. Cap and rotor are most often sold together, but I have seen them sold separately.
Old Aug 23, 2005 | 07:10 AM
hoffman4684's Avatar
Don't forget the PCV Valve.
Old Aug 23, 2005 | 07:12 AM
mike1114's Avatar
Default Re: (hoffman4684)
valve adjustment.
Old Aug 23, 2005 | 07:15 AM
tpr's Avatar
tpr
How long has it been since you replaced the sparkplug wires? If they have white powder marks where they are touching each other or other metal parts that is an indication that they need replacement. Its called ghosting, which is basically carbon tracks when the wire insulation breaks down an leaks current (spark)before it gets to the plug.
Old Aug 23, 2005 | 07:55 AM
GetawayInMoscow's Avatar
Default Re: Anything Else I Should While I'm Doing This? (tpr)
You could also seafoam it before you do all that stuff.....
Old Aug 23, 2005 | 09:14 AM
TegoDC5's Avatar
I bought the car last year but I haven't had the chance to do in a tune up, the only thing I have done was regular oil changes and air filter. So I finally decided to do a tune up, Seafoam I've been wanted to do for such a long time, I've heard nothing but great things!
Old Aug 23, 2005 | 09:24 AM
dwnthehatch's Avatar
Drain and fill the tranny. New antifreeze.
Old Aug 23, 2005 | 09:26 AM
Sleepy_Red_hatch's Avatar
Default Re: (mike1114)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike1114 &raquo;</TD></TR><TR><TD CLASS="quote">valve adjustment.</TD></TR></TABLE>
2nd that
Old Aug 23, 2005 | 09:45 AM
litterbox's Avatar
I am a (Trial User) Army
Default Re: (Sleepy_Red_hatch)
Coolant flush or
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dwnthehatch &raquo;</TD></TR><TR><TD CLASS="quote">New antifreeze.</TD></TR></TABLE>
built562's Avatar
if you bought the car last year you might want to change and flush all the fluids. oil, antifreeze, transmission and brake,
inspect all brake pads
clean engine and check for oil leaks
do your regular tune up
wash and wax
your car will feel and look a whole lot better
a saturday well spent in my book
Old Aug 23, 2005 | 01:28 PM
TegoDC5's Avatar
Default Re: (built562)
Picked up a bottle of Seafoam. :D It should be safe on a 114,000km engine '9 hatch? I'm also planning doing a tune up on my '96 as well but that has 188,000km.
ButtersNZ
Honda CR-V & Element
Nov 17, 2015 09:38 AM
Aodhan
18
Sep 20, 2007 06:13 PM
Bruce Banner
Aug 7, 2007 06:40 PM
vietkangta
Jul 28, 2007 12:43 AM
goowakjai
Jul 15, 2005 10:29 PM
