Scan tools for obd2 car with obd1 computer
does anyone know if there is an adapter for an obd2 vehicle to work with an obd1 scan tool, cuz i have a 96 civic with a 95 intetgra computer(with jumper harness obviously) and i need to figure out y my car is runnnig too rich, either stuck injector bad o2 or what so if u do let me know.
what's an obd1 scan tool?????
OBD2 cars use a scan tool to communicate to the ECU and report codes, OBD1 does not.
OBD1 uses a paperclip. see the sticky at the top of the furom for everything you need to know on how to pull codes and what they mean.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 »</TD></TR><TR><TD CLASS="quote">what's an obd1 scan tool?????</TD></TR></TABLE>
My guess is it is the tool in the third droor down on the right hand side of my tool box. And no, it's not a ******* paper clip. There is a plug that will fit into the three wire connector that is next to the two wire where you would jump it with a paper clip.
Don't open your mouth unless you truly know what is going on.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-97CX »</TD></TR><TR><TD CLASS="quote">
since I've never heard of it, please tell me what it is, who makes it.
I honestly thought there was no such thing. I've certainly never heard of it mentioned on PGMFI.org or on here.
is it a simple diagnostic tool for pulling codes or will it perform data polling like it's OBD2 counterpart?
yep whatever he said. Use the 3 wire connector green, not the 2 wire that you use for a paperclip, along with a honda adaptor. It sometimes won't work on old scanners. I got it to work on a new Snap-On brick with graphing functions (gave me codes and data), but couldn't get it to work on the old one (it would just give me codes no data).
Once again Snap-On scanner. It really expensive so unless you got one laying around I would just find a obdII ecu and diagnose with that. It's got to be a new one old one doesn't give you data, just codes. I don't know about any other scan tools that are able to communicate with honda obd I systems, enought to retreat codes. Maybe something honda dealership level scanner.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nocturnaldragon »</TD></TR><TR><TD CLASS="quote">I also use the snap-on brick scanner, but doesn't autozone have a generic one that is vehicle specific or free diagnoses?</TD></TR></TABLE>
yeah it's for obdII only I think. Either way I think only a new brick will work. Modis is still kind of getting developed I haven't tried that one on that connector.
