quick PLX-m300 wiring/stock 02 question....
Old Aug 22, 2005 | 07:29 AM
turboH22Aakkord's Avatar
Default quick PLX-m300 wiring/stock 02 question....
ok, the plx i have has the white and grey extra wires... i know one of those can be use to wire into the stock 02 wire (for dataloging) by doing this... does the plx act as a narrow band... and can closed loop be used once tunning is finished? thanks guys!
Old Aug 22, 2005 | 07:37 AM
Default Re: quick PLX-m300 wiring/stock 02 question.... (turboH22Aakkord)
ttt
Old Aug 22, 2005 | 07:49 AM
done's Avatar
the white wire if you connect it to the stock o2 wire, you should be able to datalog..
and its a true "WIDEBAND" not narrowband...
Old Aug 22, 2005 | 07:56 AM
Default Re: quick PLX-m300 wiring/stock 02 question.... (Jordo@KAP)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jordo@KAP &raquo;</TD></TR><TR><TD CLASS="quote">the white wire if you connect it to the stock o2 wire, you should be able to datalog..
thanks for verifying the color... and i knew it would be used to datalog, now, if i wanted to run open loop how would that be done? would i have to splice of the wires from the 02 sensor and the white wideband wire and then use my second 02 bung? the reason i want to run closed loop is because i live in Maine and the climate changes daily... it can be really cold one day and hot the next....
Old Aug 22, 2005 | 08:02 AM
PM-Performance's Avatar
PLX comes with Narrowband and Wideband outputs.
Old Aug 22, 2005 | 08:04 AM
Default Re: quick PLX-m300 wiring/stock 02 question.... (itr206)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 &raquo;</TD></TR><TR><TD CLASS="quote">
sweet.. thats kinda what i thought... so is there a way to wire throught the wide band to the ecu so i can use closed loop and not have to use a stock narrow band 02?
Old Aug 22, 2005 | 08:06 AM
done's Avatar
you dont need to use your 2nd o2 bung, you need to plug it up..
connect the stock "wiring", to the white wire on the plx. and then you should be fine..
edit... your going to have to ecu the ecu wire, if you want to continue to run a o2..
Old Aug 22, 2005 | 08:20 AM
Here is an easy explanation. . . .
If you just want to run it for metering and keep the stock one in too, then put the PLX as a secondary and only needs power and ground basically. Nothing else.
If you really want the Narrowband AND Wideband option and want to use that as the only sensor.
Then run a switch to go back and forth between narrow and wide.
I ran mine in Wide all the time as the primary sensor. No issues. I think I ran my ECU in open loop all the time
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jordo@KAP &raquo;</TD></TR><TR><TD CLASS="quote">you dont need to use your 2nd o2 bung, you need to plug it up..
edit... your going to have to ecu the ecu wire, if you want to continue to run a o2..</TD></TR></TABLE>
i understood the first stuff... but i dont get the ecu the ecu stuff... what did you mean by that?
Old Aug 22, 2005 | 08:32 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 &raquo;</TD></TR><TR><TD CLASS="quote">Here is an easy explanation. . . .
I ran mine in Wide all the time as the primary sensor. No issues. I think I ran my ECU in open loop all the time</TD></TR></TABLE>
but if i just use it for metering then i wouldnt be able to datalog with it right? how would i rig up a switch for it? thanks for being patient wth me! and just for future reference, what is the grey wire for?
Old Aug 22, 2005 | 10:06 AM
You can datalog with it either way I believe. But I ran mine only in wideband mode when datalogging.
Just run a switch and run each wire to a pin on the switch .
One for white and one for grey.
One is wideband , the other is narrowband. I forget which is wich becuase I use neither on my set up
Old Aug 22, 2005 | 10:35 AM
ohhh... so the white wire is wideband and the grey is narrow? so i could run a switch somewhere in the car what where the stock ecu wire and the grey and white wire meet and just switch when i need to?
Old Aug 22, 2005 | 10:48 AM
Yep.
As long as the switch it wired correctly, it should work to swap the signals when needed.
sasinorm01
Dec 28, 2006 06:24 PM
hondaj05
15
Jul 21, 2006 03:27 PM
turboH22Aakkord
Aug 24, 2005 06:17 AM
AtomiK_EK
Jun 19, 2003 06:51 PM
NO2CIVIC
Oct 30, 2002 06:21 PM
