exhaust leak at the manifold, strip at the threads in the head.. help
Old Aug 21, 2005 | 09:45 PM
rocketfuelcerx's Avatar
Default exhaust leak at the manifold, strip at the threads in the head.. help
o.k so when my vtec pops it pops louder than usual, so I check engine and see slight oil coming from the exhaust manifold area, then notice one of the bolts on the thread was missing, I just got the head put on a month ago but barely notice the problem now that I started to rev on it...anyway I put a bold on and start to tighten and notice that it only spinning...I attemp to take it back out ant the bolt and thread come out....oh ****....so the guy that I bought the head off installed it...I know he knew and I just didin't notice till now..
1) does this pose any problems to driving it around not taking it past 4000? oil consumption is about 1/3 quart for 500 miles while reving alot on it (8000) every now and then.
2) how can it be fixed?
3) should I kick this guys *** if he won't fix it?
Old Aug 22, 2005 | 10:52 AM
Default Re: exhaust leak at the manifold, strip at the threads in the head.. help (rocketfuelcerx)
bump.
Old Aug 22, 2005 | 02:31 PM
msmotorsports's Avatar
You can rethread the stripped hole using a helicoil of some sort. Oil should not be coming out of the exhaust manifold. Rings or headgasket mey be leaking. That is more important than rethreading an exhaust stud.
Bobalobagis
Oct 8, 2014 10:40 PM
shakaismith
Oct 8, 2014 06:33 PM
4g4dcruisin
Jan 5, 2013 12:46 AM
boostfever
Jan 3, 2012 08:19 PM
boostfever
Dec 26, 2011 09:15 PM
