a/c problem. Possibly pressure switch??
Old Aug 22, 2005 | 06:36 AM
DrewDown's Avatar
Default a/c problem. Possibly pressure switch??
I took my car to an A/C shop to get a hose replaced and the system recharged. Now the A/C works and blows cold air but the car will start to run hot if I leave it on. I checked the fan motor and when I jump power to it it does engage and work fine. The shop said it could be the pressure switch. Can anyone tell me how to check this?
Oh and those of you who saw this thread https://honda-tech.com/zerothread?id=1343997 will know why I am not taking it back to the shop.
Any help would be appreciated.
Old Aug 22, 2005 | 08:28 AM
drdisco69's Avatar
Default Re: a/c problem. Possibly pressure switch?? (DrewDown)
Does the fan come on by itself? I don't see how it could be the pressure switch, that just keeps the compressor from coming on when there's not enough refrigerant so it doesn't burn up. Stay away from that shop...
Old Aug 22, 2005 | 08:30 AM
DrewDown's Avatar
I think what is happening is the the fan isnt coming on causing the car to overheat and the compressor to shut off.
Old Aug 22, 2005 | 08:48 AM
drdisco69's Avatar
Default Re: (DrewDown)
That's what it sounds like to me. What kind of car is it? Check the relay for the fan, and see if it's getting power and ground and all that good stuff.
Old Aug 22, 2005 | 09:13 AM
DrewDown's Avatar
Default Re: (drdisco69)
its a 93 Integra LS. Do you happen to know where the relay is? When I get off work Im gonna check the relay. Also I was told not to run the A/C because it could build up pressure and explode.
Old Aug 22, 2005 | 09:19 AM
drdisco69's Avatar
If I remember right, the relays are in the front of the car, behind the drivers side headlight by the condensor fan.
Old Aug 22, 2005 | 09:58 AM
DrewDown's Avatar
thanks for your help, I'm gonna check the relay when I get off of work.
Old Aug 22, 2005 | 03:32 PM
DrewDown's Avatar
Thanks again for your help. I picked up a relay and everthing seems to be working now. I just think its weird because right before this I had a problem with the car overheating and it was the relay for the other fan. Seems as if they both went out at the same time. I hope nothing that I did caused that.
Old Aug 22, 2005 | 03:56 PM
drdisco69's Avatar
Excellent.
homermeza
Apr 18, 2017 06:51 AM
1999civiclx4dr
Honda Civic (2001 - 2005)
10
Aug 3, 2013 05:34 AM
ryan_1014
Feb 23, 2009 06:40 AM
Threads
11
Jun 28, 2006 04:52 PM
freddy_hung
11
Sep 21, 2003 07:32 AM
