Bad Gas Mileage
Old Aug 21, 2005 | 07:38 PM
bmw626's Avatar
Default Bad Gas Mileage
I am getting 14MPG with my 95 civic ex. I bought it with a d15b7 motor in it (suppose to have the d16z6) and it has the original ECU in it (p28). my 4 CEL's are. Oxygen sensor, MAP sensor (found out there isn't even one installed), vtec, and vtec oil switch. can these problems be causing such shitty mileage? also, if it is, which way is the cheapest way out to get my mileage back up without fixing it all at once? I already have the head and everything, just need a Vtec Solenoid. until then i cant get that installed, but i was wondering, if i get the map sensor, will that bring things up? thx
Old Aug 21, 2005 | 07:53 PM
veggiemaster's Avatar
Default Re: Bad Gas Mileage (bmw626)
well the number one thing causing your bad gas mileage is your o2 sensor. thats how your car adjusts a/f ratios. Fix that and i guarantee that your mileage will go up.
Old Aug 21, 2005 | 09:46 PM
bmw626's Avatar
Default Re: Bad Gas Mileage (veggiemaster)
well i heard if i fix my map sensor that will bring me upto 30 MPG easily
Old Aug 21, 2005 | 09:57 PM
FalkenSiR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bmw626 &raquo;</TD></TR><TR><TD CLASS="quote">well i heard if i fix my map sensor that will bring me upto 30 MPG easily</TD></TR></TABLE>
specially if you are running none
My advice would be run the B7 ECU and cut down 2 cels...
Old Aug 21, 2005 | 10:00 PM
EtherEG93's Avatar
Default Re: Bad Gas Mileage (fast88std)
will replacing a old o2 sensor help out?
i dont know if it was replaced recently, or so
but i know im not getting good mileage,
would this help and how much do they run?
Old Aug 21, 2005 | 10:31 PM
Kaji's Avatar
What mileage is that car/engine? supposed to get normally?
Old Aug 22, 2005 | 07:29 AM
bmw626's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast88std &raquo;</TD></TR><TR><TD CLASS="quote">My advice would be run the B7 ECU and cut down 2 cels...</TD></TR></TABLE>
I have a z6 head that i am getting ready to install soon that my friend gave to me, i have EVERYTHING i need minus a complete vtec solenoid
EGknoxx
Sep 18, 2008 05:08 PM
islandracer7o2
Jun 14, 2005 06:06 PM
Wiseguy619
Oct 7, 2004 12:17 AM
94 civic all mtr
Dec 20, 2003 08:18 AM
oneslodx
Sep 3, 2003 07:49 AM
