what turbo size you running on you ls?
Old Aug 21, 2005 | 03:44 PM
jdm.ej's Avatar
Default what turbo size you running on you ls?
im running a t3/t4 turbo 57/63 ar. i want to upgrade to something bigger .
right now it spools up around 2700. i was thinking sc61.
just trying to see everyone setup so i can decide what best.
so post you setups an whp numbers. thanks
Old Aug 21, 2005 | 04:08 PM
TheShodan's Avatar
Moderator
Default Re: what turbo size you running on you ls? (jdm.ej)
Heh. That SC61 will not get even halfway efficient until about 4700rpms, and will not get efficient well at all until you work on the LS head a bit. Remember, you only have 7000 rpms to work with. And a bit more stroke. What are you trying to accomplish in this setup?
Old Aug 21, 2005 | 05:02 PM
4DRCIVICB18A's Avatar
Default Re: what turbo size you running on you ls? (TheShodan)
I have a 60/.70 on my ls at 10 psi it starts at 4000 RPMs pulls all the way to 7000
Old Aug 21, 2005 | 08:26 PM
blackeg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm.ej &raquo;</TD></TR><TR><TD CLASS="quote">im running a t3/t4 turbo 57/63 ar. i want to upgrade to something bigger .
so post you setups an whp numbers. thanks</TD></TR></TABLE>
how are you getting spool at 2700?? im running the same turbo and even in 5th gear i dont start to spool until over 3k, and its closer to 3500 in like 3 and 4th gear.
that turbo is good for a decent chunk over 400hp, how much power are you making now?
Old Aug 22, 2005 | 03:43 AM
Blaze45's Avatar
Brrraaaap!
Default Re: what turbo size you running on you ls? (blackeg)
Im running the same size turbo on my B20 and I dont reach full boost until about 4k eathier. How in the world are you getting full boost @ 2700? Are you sure that your tach isnt off or something? How many lbs of boost are you running? Something doesnt sound right.
Old Aug 22, 2005 | 07:41 AM
jdm.ej's Avatar
Default Re: what turbo size you running on you ls? (Blaze45)
running about 7. with equal length mani 3 inch dp
Old Aug 22, 2005 | 08:35 AM
JoeD427's Avatar
bump for me having the same question
Old Aug 25, 2005 | 12:47 AM
playboyace35's Avatar
how is that possible?
Old Aug 25, 2005 | 01:51 AM
KhanhCord's Avatar
Default Re: what turbo size you running on you ls? (playboyace35)
he said hes running EL mani + 3"dp so it spools up sooner than the cast mani w/ 2.5" dp ..less restriction = quicker spool
Old Aug 25, 2005 | 02:29 AM
steelies's Avatar
Default Re: what turbo size you running on you ls? (KhanhCord)
I'm running a 14b
It will start spooling the second I floor it. And even under normal driving conditions.
I'm running an open 2.5" dp. And surprisingly it will hold a solid 8psi from the time it hits till redline.
DC206R
Feb 8, 2009 05:47 AM
six7one
Apr 15, 2005 06:55 PM
5STAR3
Feb 18, 2004 01:00 PM
thaiphob
Dec 28, 2003 07:28 PM
darkirony
Aug 26, 2003 01:36 AM
