power loss after car gets hot
Old Aug 21, 2005 | 02:24 PM
integragsr96's Avatar
Default power loss after car gets hot
im not sure wat the problem is but when the car sits there for atleast 2 or 3 hours turned off, then running it runs really good and smooth for a while, but after its running for more then 30 mins, it gets slow in increasing speed and picks up slow for a GSR. Every morning the car runs awsome but if i keep running it for a long time it gets sluggish. it loses the power to pick up the car well, thats not even running the AC. Ive got all these maitenance done recently at 87K miles, but it was doing this before the maitenance too, now Im at 89K miles and still doing that.
maitenance done at 87K:
Tuneup:
NGK spark plugs (V-Power Plug; BKR6E-11; DOHC; VTEC; @ Gap .052 @)
Distributor rotor (wells)
Distributor cap(wells)
PCV valve(Deutsch)
Fuel filter
Air Filter
Bleeded and renewed Antifreeze
Belts:
Belt (A/C)
Belt (Alternator)
Belt (Power steering)
Timing belt with Water Pump
Transmission Service:
Manual transmission fluid (3 quarts)
Transmission fluid drain plug crushed washer
Transmission fluid fill plug crushed washer
Bleed clutch hydraulic system
Old Aug 21, 2005 | 02:34 PM
iixerOii's Avatar
Default Re: power loss after car gets hot (integragsr96)
Try getting "better" spark plugs. You do have the right spark plugs and gap for your car but even stock they had platnium tipped spark plugs.
Old Aug 21, 2005 | 03:38 PM
Default Re: power loss after car gets hot (iixerOii)
sorry those are not the spark plugs used, I cant rmr the exact model, but I know I got the recommended model from honda-tech,.
Old Aug 21, 2005 | 05:11 PM
98_gsrteg's Avatar
I made a thread on this exact problem I was having. Here is the link.
https://honda-tech.com/zerothread?id=1277394
I have yet to change the cap and rotor but the problem has seemed to go away. I don't know why or maybe I just don't pay attention to it. Still going to change my cap and rotor (maybe even whole dizzy) since I know it needs to be done.
Old Aug 21, 2005 | 05:30 PM
00DC2's Avatar
im not too sure but isnt that what they call heatsoke or something like that...makes ur car boggy and lose performancce...i believe it happens in basically every car
on a side note..i finally logged in now that i remember how to spell my usernmae
Old Aug 21, 2005 | 07:03 PM
batmang yO!
Guest
Posts: n/a
Default Re: power loss after car gets hot (00DC2)
Dude, my 97 GSR is doing the same crap, only it tends to hesitate sometimes as if its not getting a spark, it started around 80-85k miles and im now just over 100k miles.
Old Aug 21, 2005 | 07:16 PM
TOPFUELER's Avatar
Thats funny i also had the same problem in my 2000 gsr with 38thou miles. Morning dive to work runs like a champ, afternoon drive how it fells kinda slugish. I am guessing it might have to do with tempature issue are its all in my head not to sure thoe. I did a basic tune up and now it seems to be driving up to par.
Basic tune up:
NGK spark plug wires
NGK Irridum plugs pre gap
Honda fuel filter
Old Aug 21, 2005 | 07:23 PM
TOPFUELER's Avatar
That's funny I also had the same problem in my 2000 GSR with 38thou miles. Morning dive to work runs like a champ, afternoon drive home it fells kind of sluggish. I am guessing it might have to do with temperature issue are its all in my head, not to sure thoe. I did a basic tune up and now it seems to be driving up to par.
Basic tune up:
NGK Iridium plugs pre gap
Honda fuel filter
Mobil 5w30 fully synthetic/Honda oil filter
Honda tranny oil
Cap and Rotor
Valve adjustment and installed my new Aem cold air intake. Runs A lot better now..Also I was told not to mess with the gap on the iridium plugs cause it could distort something in the plug, not to sure thoe...
Old Aug 21, 2005 | 07:29 PM
playalistic2's Avatar
Same thing with my car. When I first drive it's a beast when its hot it boggs at high rpms.
Old Aug 21, 2005 | 07:33 PM
quicky_hatch12's Avatar
Default Re: power loss after car gets hot (playalistic2)
Wtf I made the same thread https://honda-tech.com/zerothread?id=1347048 I thought if I got an external msd coil it run better when it's hot is this true.
Old Aug 24, 2005 | 01:21 AM
Default Re: power loss after car gets hot (98_gsrteg)
yeah I read you thread before, I did all the maintenance by reading your thread hoping it would fix my problem but nope. Im not sure what can be causing it even tho Ive changed my cap and rotors. And yes the clutch gets hard to press down too just like how u described it on your thread.
Old Aug 25, 2005 | 02:42 PM
00DC2's Avatar
Default Re: power loss after car gets hot (TurboLiLcIvIc605)
use heat wrap on ur headers, get cooling plate and some heat insulation.
it wont bog as much..because itll cut down the heat in there a lot n wont be too heatsoaked...your problem can be something technical or just the heat..looking at most who posted..ur in pretty hot temperature places.
im in jacksonville FL n both my gsr n my bros prelude loses power in this heat..so do lots of the other cars around.
Old Aug 25, 2005 | 03:22 PM
temp's Avatar
um.....is your cat clogged? have you bothered to check it?
RSKtakR
Honda CR-V & Element
10
Jan 19, 2016 04:23 AM
PhantomGSR
Jun 30, 2013 07:18 AM
Nocturnal
11
Feb 6, 2006 10:40 AM
Seks
Aug 9, 2004 12:55 PM
quikrpm'z
Feb 19, 2003 03:14 AM
