tranny problem
I was driving today in 5th gear (cruising) and it popped out. Everytime I try to push it into gear it will almost immediately pop out. When try to engage 5th gear, it will scratch..? Has anyone ever had this problem? Anyone know a solution?
thx,
Mark
thx,
Mark
Check your motor mounts, see if they are broken, or rubber worn out, and let the engine rock too much...
Check your shifter for the same thing - see if it's too sloppy.
Also see if the tranny is full on oil.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nikitad »</TD></TR><TR><TD CLASS="quote">Check your motor mounts, see if they are broken, or rubber worn out, and let the engine rock too much...
Also see if the tranny is full on oil.</TD></TR></TABLE>
B16Jacques
Sep 17, 2006 09:26 PM
93egSIboi
24
Feb 10, 2005 04:40 PM
i HAVEtheADVANtage
17
May 28, 2003 10:58 PM
