LS hatch died all of a sudden....there is no spark????
Old Aug 20, 2005 | 02:48 PM
EFz6er's Avatar
Default LS hatch died all of a sudden....there is no spark????
My LS hatch died on the side of the road yesterday......the dizzy isnt sparking. We tested the pickup coil and ignitor and they tested good. Then we changed out ignition module and it wont spark......what else could have gone wrong or bad?
Its getting fuel and turns over strong it just wont spark
Any info will be greatly appreciated
Old Aug 20, 2005 | 02:59 PM
Skinflute22's Avatar
wires, plugs? cap, rotor?
Old Aug 20, 2005 | 03:13 PM
EFz6er's Avatar
Default Re: (Skinflute22)
who cares about the plugs...the dizzy aint sparking. rotor is good as well as wires and the cap was bought new 2 weeks ago
Any other ideas???
Old Aug 20, 2005 | 03:20 PM
jc836's Avatar
Default Re: LS hatch died all of a sudden....there is no spark???? (EFz6er)
Did you check the ECU for a CODE. If you get either a 4 or 9 go buy a new distributor as the parts in the base cannot be replaced. The other thing in the housing to look for is a coating of a reddish dust which means the bearings are gone. Finally, make real sure that the connectors outside are indeed OK. Hope this helps
Old Aug 20, 2005 | 03:37 PM
EFz6er's Avatar
Default Re: LS hatch died all of a sudden....there is no spark???? (jc836)
i screwed up and i exchanged ecu's just out of curiosity before checking for new codes to see if possibly the ecu went bad so when I re-hooked up the original ecu there were no codes flashing.....before like last week I had code the code for the IACV, 14 i think, but thats nothing.
Im probably going to end up buying a new dizzy but if H-T can save me the $300 for a new one it would be awesome.
the housing looked clean, not any reddish dust.
TexasluvsHondas
Jan 1, 2007 05:23 PM
zerogravitycrx
87
Dec 15, 2006 12:03 PM
Kamin
Jul 31, 2003 07:45 AM
2k1_ITR_0736
17
Jan 26, 2003 04:09 PM
Urban Business
12
Dec 22, 2002 12:28 AM
