how do you bypass the map sensor on turbo ls without a missing link!!! help asap(8/20)
Old Aug 20, 2005 | 01:20 PM
BIGblock97's Avatar
Default how do you bypass the map sensor on turbo ls without a missing link!!! help asap(8/20)
please help i need a way to bypass the map sensor temporarily until i can get a missing link please help !!!!????
Old Aug 20, 2005 | 01:32 PM
flip1199's Avatar
Default Re: how do you bypass the map sensor on turbo ls without a missing link!!! help asap(8/20) (no-vtec9
what are u using to tune it? if your using uberdata/crome/hondata/neptune u dont need a missing link. if your runnng an fmu or something similar u can go to a fish store and get some check vavles.
Old Aug 20, 2005 | 02:14 PM
s2kdre's Avatar
there is no way to bypass it, unless u dont boost
Old Aug 22, 2005 | 03:11 PM
BIGblock97's Avatar
the check vavle idea doesn't work tried it
i am about to get uberdata wed. so hopefully this will fix all of my problems
Old Aug 25, 2005 | 09:40 PM
zerospeed's Avatar
you need at least 5 check valves to make it work...thats what i was using with a fmu on 14 psi
Old Aug 25, 2005 | 10:30 PM
SOHC_MShue's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zerospeed &raquo;</TD></TR><TR><TD CLASS="quote">you need at least 5 check valves to make it work...thats what i was using with a fmu on 14 psi</TD></TR></TABLE>
14psi? Not very smart...
They are right about just using the check valves though. Thats all you need, but why not wait a few days until you get some real managment? I've known a number of people who wanted to "test" their car out with their fmu a few days before they got tuned with something much better and ended up blowing their motor up within the first few boost pulls.
Tr0LL
Jan 4, 2008 09:25 AM
Vinhtran17
Mar 30, 2004 09:30 PM
JediPimpCrx
Apr 4, 2003 12:25 PM
ludelvr
May 31, 2002 06:20 PM
97GSRT
Mar 29, 2002 04:34 PM
